Upper engine mounting bolts
Hey everyone,
I'm looking to install a set of SW-Motech crash bars on my CB1100, but I don't have the Honda service manual. Can someone tell me what the torque specifications are for the 4 upper engine mounting bolts? (the two bolts on either side towards the front of the engine) Much appreciated, thanks!
The manual says 36 ft/lbs for the 2 on the frame, 44 ft/lbs for the one connected to the engine.
I had a heck of a time on the 2 front bolts - they were on very tight.
(05-19-2014, 04:46 AM)CB4ME_imp Wrote: The manual says 36 ft/lbs for the 2 on the frame, 44 ft/lbs for the one connected to the engine.
CB4ME
I'm kind of weary about installing mine.
Is this picture correct on the torque ?
Which bolt/nut did you torqued first?
Did you do a side at a time?
Did you prop something (car jack) under the engine?
And can anyone else verify this?
Sent from my SM-G955U using Tapatalk
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 423 04-03-2021, 01:35 AM
  Weak Crank Case Bolts? bertypower_imp 19 1,542 09-12-2020, 10:22 AM
Last Post: bertypower_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 332 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Front fork plug/bolts. FLYTYM_imp 1 255 04-12-2019, 09:53 PM
  tips for busting extremely tight frame bolts? misterprofessionality 54 3,851 10-04-2018, 01:59 PM
Last Post: SportsterDoc
   Right side crankcase cover bolts Shestak_imp 15 984 05-25-2018, 03:43 AM
Last Post: 2017EX_imp
  Broken shock bolts woodsparrow_imp 15 971 05-17-2017, 01:36 AM
Last Post: aschem_imp
  Chain adjuster bolts Jaychaynes_imp 3 333 08-23-2016, 09:45 PM
Last Post: Riko_imp
  Handlebar bolts Mr Jangles_imp 3 377 07-19-2014, 11:06 AM
Last Post: Mr Jangles_imp
  Mounting the Honda Rear Rack Capo 18 1,314 05-11-2014, 12:32 PM
