tips for busting extremely tight frame bolts?
far be it for me to complain about Honda bolting things together with extreme care, but I just tried to install my new frame sliders only to discover that i am physically incapable of moving the bolts, even a tiny fraction of an inch. These are the same mounting points used for a lot of engine guards, so I'm sure some of you have encountered this before.
Any tips out there on how to get these bolts to move? i mean it, my ratchet just disintegrated in my hand trying to turn this bolt. there must be a trick to this.
6 point socket
Breaker bar
Rubber mallet
ahha...so spending more money on more expensive tools....sigh...why does that always turn out to be the answer? guess i'm waiting a month to install these then.
Did you break the socket handle? I have broken one on a particularly tough nut. Otherwise, the normal handle augmented in length by a decent length of galvanised water pipe will do the trick. You just need a bit of leverage. Otherwise, the breaker bar is not too expensive and, provided you get the right size head, will use your normal sockets. It's not a bad investment on the tool front.
I just ran up against the same wall yesterday. I bought frame sliders from another forum member, went to install them and discovered that those bolts are really on there tight! I didn’t feel like digging out my breaker bar at the moment, but I’ll do it tomorrow with confidence that it’s the right tool for the job.
I guess what I mean to say is you won’t regret owning a breaking bar if you want to spend more time wrenching. It’s practically required equipment and they’re worth their weight in gold when you need one. Consider it an investment.
I was going to suggest a battery-operated impact wrench with about 1000 foot-pounds torqueing ability, but I guess you wouldn't want to spend that kind of money.
Tools I suggested are very basic must have type...constituting poor man's impact...more effective than leverage.
See directions for this VW axle temoval tool
http://www2.cip1.com/ProductDetails.asp?...C-C10-7045
(09-30-2018, 12:47 PM)egleaves_imp Wrote: I just ran up against the same wall yesterday. I bought frame sliders from another forum member, went to install them and discovered that those bolts are really on there tight! I didn’t feel like digging out my breaker bar at the moment, but I’ll do it tomorrow with confidence that it’s the right tool for the job.
The front engine mount bolts were very tight when I took them off my bike, partly due to the constant heat cycles that turn any condensation into a chalky white residue.
The 4 nuts are partly obscured by the header, but I was able to put a box end wrench in place and hit it sharply with a plastic mallet, easily breaking the nuts loose with a loud creak.
Trying to turn the bolt head is the wrong way - too much energy lost on the twisting bolt. Always turn the nut, not the bolt.
I used a 2 ft. breaker bar. Leverage is your friend. Big Grin
I usually don't like to spend a lot on tools that I won't use very often, but a breaker bar is relatively inexpensive and is very useful on stubborn bolts. I also use mine for loosening/tightening the rear axle, since it tends to spin if you only turn the nut side.
(09-30-2018, 12:21 PM)misterprofessionality_imp Wrote: far be it for me to complain about Honda bolting things together with extreme care, but I just tried to install my new frame sliders only to discover that i am physically incapable of moving the bolts, even a tiny fraction of an inch. These are the same mounting points used for a lot of engine guards, so I'm sure some of you have encountered this before.
first step is penetrating oil--I give the nut and bolt a good soaking with PB Blaster and let sit for awhile (ideally overnight) and that usually does the trick. breaker bar or rubber mallet only if needed, but I prefer to use as little brute force (and new tools) as necessary
  Black Frame Paint spechg 12 1,039 06-24-2026, 08:12 PM
Last Post: HondaLou
  frame gusset threaded hole question tdbru 0 224 10-27-2024, 11:27 AM
Last Post: tdbru
  New members tips max 54 4,282 10-29-2023, 12:11 AM
  Opinion on frame damage MxHansen_imp 29 2,117 11-16-2021, 11:46 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 405 04-03-2021, 01:35 AM
  Some valve adjustment tips and tricks. LakeWylieJoe_imp 58 5,378 01-18-2021, 02:06 AM
Last Post: bflint
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,305 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  Mystery dent on frame? Should I be worried? bertypower_imp 14 1,170 10-04-2020, 02:41 AM
Last Post: bertypower_imp
  Weak Crank Case Bolts? bertypower_imp 19 1,500 09-12-2020, 10:22 AM
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 872 04-13-2020, 05:47 AM
