Chain adjuster bolts
These chain adjuster bolts are a little different than my last bike. Does anyone have a video or advice for adjusting these particular bolts for chain adjustment or after replacing tires?
Thanks.
That question is in the wrong place, but this might help: http://cb1100forum.com/forum/showthread.php?tid=2708
Also read Ferrets link to the original How-to that he links to. He metions the chain adjustment. It really isn't rocket science Smile
is this what you are looking for?
http://cb1100forum.com/forum/showthread.php?tid=7158
(08-23-2016, 01:16 AM)Jaychaynes_imp Wrote: These chain adjuster bolts are a little different than my last bike. Does anyone have a video or advice for adjusting these particular bolts for chain adjustment or after replacing tires?
Thanks.
without going in to detail right now (I'm sure somebody can or already has posted the link with pics and specs)
but just loosen the big bolt, and turn on both adjuster bolts (clock or counterclockwise for more tension, manual states the details)
what I do, is I don't losen the big bolt completely, cause if that's completely lose your wheel can slide forwards and you want to have more tension so the wheel has to go rearwards...
Every adjustment made can be undone when tightening the big bolts.
So I loosen the big bolts just enough so I make tension of the chain turning the adjuster bolts.
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 432 04-03-2021, 01:35 AM
  Weak Crank Case Bolts? bertypower_imp 19 1,582 09-12-2020, 10:22 AM
Last Post: bertypower_imp
  Front fork plug/bolts. FLYTYM_imp 1 261 04-12-2019, 09:53 PM
  tips for busting extremely tight frame bolts? misterprofessionality 54 4,025 10-04-2018, 01:59 PM
Last Post: SportsterDoc
   Right side crankcase cover bolts Shestak_imp 15 1,010 05-25-2018, 03:43 AM
Last Post: 2017EX_imp
  Upper engine mounting bolts skimhitz_imp 2 290 06-02-2017, 04:58 AM
Last Post: jdvalero_imp
  Broken shock bolts woodsparrow_imp 15 1,016 05-17-2017, 01:36 AM
Last Post: aschem_imp
  Handlebar bolts Mr Jangles_imp 3 382 07-19-2014, 11:06 AM
Last Post: Mr Jangles_imp
