 Right side crankcase cover bolts
I'm having some problems finding the torque spec for the bolts. Any help would be appreciated. Thanks
The little one is the right crankcase cover.
There is no torque spec listed. The procedure tells you to put the sealant where shown and tighten the bolts securely.
So, you either do that, or use the Standard Torque Values Table in the General Information section of the manual. Its section 1.
If you need the values, let me know.
Hope this helps
https://imgur.com/a/J7Vb875
pb
Thanks PB! I was going to have to email it to him.
I really need to get back on a photo hosting service...
(05-02-2018, 08:48 AM)Lord Popgun_imp Wrote: Thanks PB! I was going to have to email it to him.
No problem...sometimes ground people are faster than avionic Tongue
pb
Angry. Big Grin
Thanks guys! I don't have a manual, should get one. What type of sealant?
Three Bond 1207 B or equivalent.
Google it and it comes up at a number of sources. Amazon has it too. I don’t know what the equivalent is. Here is a link to the data sheet for it.
Yes you need a manual. You are seeing why right now.
Why did you take the cover off? I would guess that the CKP sensor rarely goes bad.
No link, popgun.
Sorry—again. I’ll get it after work
  Right Crankcase Cover missing from service manual? bflint 4 636 07-30-2025, 11:55 AM
Last Post: bflint
  Left side cover removal jeffmazz_imp 24 1,999 07-09-2025, 03:37 PM
Last Post: bflint
  Left Side Crankcase Gasket Part number. jbird06_imp 1 314 03-26-2024, 08:56 AM
  2014 CB1100 Right crankcase cover msundst_imp 16 1,259 06-03-2023, 06:09 AM
Last Post: TX Silver_imp
  Question on replacing engine side cover Ollie 11 763 01-10-2022, 11:21 AM
Last Post: Ollie
  2014 Right Side Cover--Red eddi0_imp 12 1,105 06-07-2021, 09:16 PM
Last Post: eddi0_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 394 04-03-2021, 01:35 AM
  Weak Crank Case Bolts? bertypower_imp 19 1,470 09-12-2020, 10:22 AM
Last Post: bertypower_imp
  Colour code for grey crankcase Mabel_imp 10 1,096 08-27-2019, 01:17 AM
Last Post: Frulk_imp
  Front fork plug/bolts. FLYTYM_imp 1 242 04-12-2019, 09:53 PM
