Wheel Speed Sensor Clip?
Was cleaning the bike and found that the little cable that goes to the wheel speed sensor was not connected correctly. The little clip for the cable appears to be broken. Can anyone share a pic of a good one? Zip tied for now.
[url=http://s126.photobucket.com/user/cwwskw/media/e913ebc4-314b-4805-ae96-78a2bd8578a6_zpswvwgg0xj.jpg.html][Image: f93458eeaeb895c12ab3397c1352b66e.jpg]
(07-07-2017, 09:41 AM)TwoBrothersBusa_imp Wrote: Was cleaning the bike and found that the little cable that goes to the wheel speed sensor was not connected correctly. The little clip for the cable appears to be broken. Can anyone share a pic of a good one? Zip tied for now.
Here is a shot of mine. It's a double snap piece of plastic. You should be ready to go with the cable tie. By the way, mine was not snapped on the break line. Thanks for the heads up!
Thanks for the snapshot! The things that zip ties have done for me over the years...
You guys just made me go look at mine. It is installed on the brake line ok, but twobros, yours is backwards compared to my '13.
Mine looks like Retsel's, except it is seated on the brake line. IOW, it snaps on from the outside. The service manual may show it, I'll have to check.
In looking at the clip, its plastic and I think may get hard and be easy to break in the future. I may order a spare for later.
Looked at mine. it comes up from the bottom with open end for wire on top
  CB1100 Idle speed instability problem ericlo69_imp 1,436 124,947 08-20-2026, 12:54 PM
  Front wheel bearing noise? MagnaRider 20 1,991 03-31-2026, 08:20 AM
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 3,178 03-06-2026, 04:31 AM
  This is why wheel bearings are failing 1973cb750 3 375 02-05-2026, 08:11 AM
Last Post: 1973cb750
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 588 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 949 10-22-2025, 02:11 PM
  CB11OO EX wheel rims sprint 6 722 02-26-2025, 06:16 AM
  New speed meter replacement ACE_IRA_imp 3 533 02-13-2025, 06:25 AM
  How to remove O2 sensor CB1100AZ_imp 10 991 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Bank angle sensor. Tezza_imp 8 826 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
