Threads: 13
Likes Received: 79 in 49 posts
Likes Given: 45
with this amount of grease in the oem factory bearings no wonder people have had failures.
if you have never changed yours I recomend you do, if you can. thats no grease I'll be inspecting the new oem honda ones and adding some grease tomorro if they need it putting on a 160 avon
Threads: 33
Likes Given: 95
This would be quite normal with many manufacturers, over packing a bearing with grease is not good for it. You can cause high temperatures and damage seals with all the extra friction. This was drummed into us when I was a Marine Engineering apprentice at 16 years old.
Threads: 13
Likes Given: 45
02-05-2026, 07:08 AM
(This post was last modified: 02-05-2026, 08:08 AM by 1973cb750.)
A smear would be one thing a pea sized dot is more than whats in these i have taken appart a lot of wheel bearings this is the least amount of grease i have seen in them period
the funny part is the same wheel opposite bearing had the normal amount in it
Threads: 13
Likes Given: 45
02-05-2026, 08:11 AM
(This post was last modified: 02-05-2026, 08:12 AM by 1973cb750.)
i greased the new ones shouldn't have any issue with them
