Torque Settings For Bars & Levers Please?
Hi Folks,
I had to slacken the handlebar clamp and higher the bars slightly on my 1100 ex.
Does anyone with a Service Manual know the correct torque values for -
Bar Clamp
Brake & Clutch Lever Perch
Bar Switch Units
Cos I think they all might need adjusting slightly and the bar clamps definitely need re-torqueing.
Is there a torque setting chart anywhere on here ??
Many Thanks
The 4 handlebar clamps are 15 ft lbs. Tighten the top ones first.
Clutch master cylinder holder bolt (2)—9ft lbs. Same for the brake bolts
Bar switch units are not listed in the table or manual section on them. So use the Standard torque values table. They are screws, so 5mm screw is 3.1 ft lbs, and 6mm screw is 6.6 ft lbs.
Great Thanks,
Will do
Biker
  Torque value question Jonnyteabag_imp 9 656 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 644 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Stock Bars to Renthal 758 Super Lows Phadreus_imp 4 397 08-02-2021, 10:58 PM
Last Post: Phadreus_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 405 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,575 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  levers andyoz_imp 5 488 06-06-2020, 07:31 PM
Last Post: andyoz_imp
  Shock bolt torque HBFL_imp 9 695 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,114 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,201 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 382 09-10-2018, 07:35 AM
