Threads: 4
To all electrical wizards: would it be hard to modify the CB1100 electrical wiring in order to swap the light horn and sound horn switches?
Has anyone ever tried adding/substituting a form of sound horn switch underneath the turn signal?
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
Someone has swapped 2013 and 2014 controllers before. The 2013 has the standard horn and turn controls. 2014 had them swapped. Parts are interchangeable from what I understand.
Likes Given: 1,002
The Ferret did it. See
http://cb1100forum.com/forum/showthread.php?tid=3549, although the pictures have gone.
Threads: 125
I put both sides '13 controls on my '14- both for the more traditional look, and to stop hitting the horn all the time.
If I remember correctly the locating pins were in a different spot- but I was swapping on rebel handlebars at the same time so had to drill anyway.
The wiring and plugs were the same, no modifications needed.
Likes Received: 607 in 272 posts
Likes Given: 784
Yep put a 13 switch on mine as have a few others. Plug and play except for drilling a new locating hole, and the 13 uses different length screws.
Threads: 63
Likes Given: 8
(06-16-2018, 05:16 PM)Cormanus_imp Wrote: The Ferret did it. See http://cb1100forum.com/forum/showthread.php?tid=3549, although the pictures have gone.
I swapped mine also.
