Dodgy Kill Switch
While riding home today I momentarily released the throttle as I slowed for a stop. My index finger brushed the kill switch lightly and the motor quit. I checked the switch and it was in the on position. I switched off the ignition, then back on. No lights on the panel. I then switched the kill switch to off and then on, all lights back on and the motor started. I then brushed the kill switch again lightly with a finger tip and the motor cut off. Resetting the switch got things going again and I was on my way. Anyone noticed this on their CB before?
Personally I've never felt the need for these devices in the first place and in 50 years of riding have never had the need of one.
Haven't noticed anything like that and I'm afraid to go try it. Like you, I've never had the need for the switch. All it's ever done is cause me confusion and frustration after cleaning the bike and not realizing that I had tripped the switch. Took forever to figure out why the bike wouldn't start! Another proud moment in my motorcycling history.
Checked both of my bikes both the same. I rocked the kill switch slowly to off at about half way kill them! Rocked it back from halfway off to on both ran.
Never touch that switch so I have no idea if its sensitive or not? Good to know though in case it ever won't start.
(11-04-2014, 08:14 PM)The ferret_imp Wrote: Never touch that switch so I have no idea if its sensitive or not? Good to know though in case it ever won't start.
Same here; good to know, but I never use the kill switch either.
One of my bikes is a '67 Triumph Bonneville chopper. One day when I cranked it up coming off a light, the throttle stuck wide open. I managed to shut her down with the key but home I went and added a kill switch. Fortunately I've not had to use it but I'm sure glad it's there.
I think you should use, or at least work the switch from time to time just to prevent the chance of corrosion build up.
I don't think you describe a dodgy switch as much as its a sensitive switch. That might be a good thing someday in a panic situation where you want it to shut down right away. Just learn to keep your frickin fingers off the thing and you'll be fine! Wink
(11-04-2014, 11:19 PM)ClassicVW_imp Wrote: I think you should use, or at least work the switch from time to time just to prevent the chance of corrosion build up.
I call it dodgy. A switch that is a bit too easy to activate I would call sensitive. This switch was "tripped" by merely brushing it with a fingertip, so lightly that the switch did not perceptively move.
I intend to open the switch housing and find the problem.
Kill switches are an anachronism that may have been needed in
the past. On a modern fuel injected bike they're just another place to have electrical problems. Just ask some Moto Guzzi owners.
Yeah, you can't make it fool-proof enough. Big Grin
I used a kill switch only one time when SUDDENLY the carbs raced to full speed and the kill switch saved my bacon.
  Delay when using headlight switch? Jgarciajr40_imp 15 1,147 12-05-2022, 07:11 AM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,904 10-08-2022, 12:27 PM
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,973 07-12-2022, 08:04 PM
Last Post: tommymck
  Need a starter switch but none available Kdogg2077_imp 11 977 07-05-2021, 01:56 AM
  Turn Indicator Switch question Scotty_imp 6 517 09-22-2020, 11:58 AM
  Putting 2013 horn/turn signal switch on a 2017 pekingduck 9 654 01-02-2020, 08:37 AM
  2014 Start - Cutoff Switch Question deltamark 16 1,285 04-18-2019, 06:23 PM
Last Post: flynrider
  Horn switch position johan_imp 5 422 06-18-2018, 10:55 AM
  Front brake light switch iffy Ulvetanna_imp 0 170 06-12-2016, 10:38 AM
Last Post: Ulvetanna_imp
