Front head light position
Hello forumHello
I have my CB 1100 in the garage and looks perfect to my eyes.
I have 2 other bikes right now and have learned about them and their needs , this one however is very new to me. so you will see me posting a lot of questions to the forum.
I needed to ride the CB at night , I was riding in the city and streets and freeway were very well illuminated by lights.
I however realized the front head light ,either at high or low beam focuses at something like 10 feet in front of me.
I don't know if it is because of windshield bracket installed that limits the movement of light or it is the factory design. I think I have dart windshield and bracket. Thanks
Thank you
Ride safe/Ride long
Hi Ennsync!
Do you have a closeup of the mounting?
I adjusted my headlight some months ago and had no problem to increase height.
Greetings to my beloved SoCal,
Markus
(10-10-2018, 04:02 AM)Ennsync_imp Wrote: Hello forumHello
Thank you
Ride safe/Ride long
i actually had the exact same issue early on, and I noticed it after installing my own Dart screen. if you just loosen those two bolts on the side, tilt the lamp up a bit, and retighten them it will be much better. after I adjusted the angle my low beam is catching objects way out in front of me.
I'm still going to swap to an LED lamp at some point though.
Thank you both for the response, I will try to do so.
Ride safe/Ride long
Check out this thread, too. http://cb1100forum.com/forum/showthread.php?tid=905
(10-10-2018, 08:09 AM)Cormanus_imp Wrote: Check out this thread, too. http://cb1100forum.com/forum/showthread.php?tid=905
Thank you , will do so and update.
Ride Safe/Ride Long
  Brake reservoir screw head issue satchit 72 5,551 04-24-2022, 11:55 PM
  Chrome cylinder head cap Juancho76_imp 21 1,802 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Cams, Compression, Head Work? boynton6spd_imp 12 1,000 08-08-2021, 02:27 AM
Last Post: old blue_imp
  CB900 Custom oil stopper on valve head AOrhun_imp 9 844 01-27-2021, 10:06 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 776 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 663 09-01-2020, 12:19 AM
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,431 04-15-2020, 01:53 AM
  running light and brake light Ennsync_imp 3 443 01-02-2019, 11:24 PM
   H4 Head light Bulb Question Ennsync_imp 36 2,645 12-30-2018, 01:48 PM
  Speedometer Allen Head screw loose mhicks17_imp 1 268 09-15-2018, 02:55 PM
Last Post: max
