Synthetic oil & clutch operation
It might be my imagination but.... I have changed the oil from Semi Synthetic 10-30W to fully Synthetic 10-40W. I have been for one ride only of around 200kms with a bit of in town time, it seemed to me the clutch take up had become quite short in comparison from what it used to be (so from clutch level full in against handgrip to when bike was smoothly moving the lever movement seems short and close to handgrip end rather than over length of level throw).
I have before this bleed the clutch master cylinder so its air free and has new fluid in it.
Has anyone noticed any difference when doing similar oil wise?
Is the new oil still JASO MA ?
(11-04-2021, 07:13 AM)j3gq_imp Wrote: Is the new oil still JASO MA ?
yes it is
I’m going to make another batch of popcorn
.sorry
(11-04-2021, 10:19 AM)gmike_imp Wrote: I’m going to make another batch of popcorn
This one is a little slower than typical. Almost like molasses in winter.
I'll throw a small spanner in: "Is it JASO MA2 certified?"
Are you saying you bled the clutch at the same time as this oil change? If you did and now have fresh clutch fluid one might expect it to operate on less of a lever movement if the old fluid was in poor shape, maybe holding a little air.
Just to clarify, you said you bled the master cyl. You did do the bleeding at the slave cyl. correct?
Ok thanks everyone for the input, I have fixed my imagination..
At same time as I changed the oil, I fitted a set of Grip Puppies on top of my Oxford Hot Grips. I removed them for ride today and issue has gone so seems the grip puppies make the grip to big for my hands and give less control of clutch in particular.
Lesson learnt....
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,285 12-24-2025, 11:14 AM
  Fully synthetic or not. balkanhound_imp 20 1,819 03-07-2025, 04:01 AM
  Replace clutch Lever Davidjill_imp 10 993 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,082 11-22-2024, 07:49 AM
  throttle operation The Gecko_imp 6 625 03-07-2024, 09:39 AM
  Great deal on Castrol Synthetic Gone in 60 1 272 02-16-2024, 01:57 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 246 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,537 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 656 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 515 02-21-2023, 10:48 AM
