Fully synthetic or not.
I have been running Rotella T5 15w40 synthetic blend in my 2017 EX. Sounds quiet and shifts smooth as butter.
"Bob is the oil guy" - lots of mentions of the CB1100 on this subject. 10W-30 and 15W-40
http://bobistheoilguy.com/forums/threads...il.369288/
I just find it awfully easy to choose the spec. the manufacturer states, it takes all the guessing out of it. I find the biggest impact on my bike for gearbox smoothness is the correct adjustment of the chain slack.
Tev62_imp dateline="0' Wrote: "Bob is the oil guy" - lots of mentions of the CB1100 on this subject. 10W-30 and 15W-40
I believe that is actually the info that I referenced when I made the oil/oil filter cross reference table thread for members. Lots of info on that site
https://cb1100forum.com/forum/showthread.php?tid=14295
This was the thread. In hindsight I don't think i used the proper verbiage to explain why the 10w-50 is used over 10w-30 according to my bike shop.. but I was just trying to relay the info at the time lol.
The list of filter serial numbers should still be accurate though
It's not a bad conversation and interesting he found a difference between his two bikes.
I have been using the Mobil 1 M108 or M110 depending on price and availability. Has anyone here used the Mobil M1MC-134 motorcycle specific filter and noticed any difference between that and the M108/M110 or the Honda OEM 15410-MFJ-D01?
The CalSci post you referenced shows the thread and PSI ratings, but I can't find anywhere that references the Honda 15410-MFJ-D01 specifics on PSI. Obviously it has the same threads, but I am curious to know if those are truly an identical replacement as CalSci suggests.
Asking because I am wondering if I should be using the motorcycle specific Mobil M1MC-134 .vs the M108/M110.
Asking because I am wondering if I should be using the motorcycle specific Mobil M1MC-134 .vs the M108/M110. I think I did actually get the MC specific one at some point but usually just use the 110 i believe.
As far as making a difference that's more of a science/engineering question that i don't know the answer to.
If you could get the MC filter at half the price of the M110, would you use it instead?
I don't see why not. I marketing aside I don't think its a bad thing to go with a model or product thats made specifically for a motorcycle over just a general motor.
Again I don't know if there truly is a difference but you're gonna be safe with either option so why not grab the less expensive one IMO.
You will have to excuse me if this has been covered before but coming to the end of winter here and time for some fresh oil for the summer. I would like to use fully synthetic but remember that fully synthetic made the clutch slip on my old suzuki bandit. What oil do you all recommend. Castrol or Motul are ready available here.
Thanks nick.
As long as you use motorcycle-specific oil, either regular or synthetic will be fine. Been using Castrol synthetic in mine since I've had it and no slipping problems at all.
  Great deal on Castrol Synthetic Gone in 60 1 250 02-16-2024, 01:57 AM
  Synthetic Brake Fluid Wagonpeddler_imp 3 369 02-18-2023, 07:49 AM
  Synthetic oil & clutch operation Rogerdj_imp 8 669 11-08-2021, 06:41 PM
Last Post: Rogerdj_imp
  Synthetic Oil smell? bertypower_imp 2 339 09-13-2020, 11:10 AM
Last Post: bertypower_imp
  Center Stand Doesn't Always Retract Fully emptysea 4 334 01-03-2020, 04:47 AM
Last Post: LongRanger_imp
  Performance boost from synthetic Darpo_imp 6 540 02-08-2019, 02:34 PM
  Tirox Synthetic Chain Wax redbirds_imp 3 304 06-11-2015, 10:59 AM
Last Post: kmoney_imp
  Switching to synthetic oil... Bike #12_imp 39 2,355 07-11-2014, 02:02 PM
Last Post: OldF7Guy_imp
  Can synthetic go 4K between change? HikerToo_imp 20 1,261 10-08-2013, 06:15 AM
Last Post: flynrider
