spark plugs after 70.000 Km
So, having never changed the plugs or even take. Them out, at 32k miles and 11 years, I’m guessing it’s time to. My worry is messing up the holes since they’ve been in there so long. The plan so far is to use some penetrating oil, then getting the engine up to operating temperature, and a lot of patience to work them out.
Any other tips?
Make sure you've thoroughly cleaned the area around the plugs so nothing can fall through the hole when they come out.
Cormanus_imp dateline="0' Wrote: Make sure you've thoroughly cleaned the area around the plugs so nothing can fall through the hole when they come out.
Will do. Thanks!
For some reason we decided to have a look at the sparkplugs which are the original ones on the 2010 cb1100.
Something vitally importand on this bike is to clean any debris around the sparkplugs so as to prevent sand, small rocks and other hard things falling into the cylinder and " make themselves at home there " .
We pried some small loose rocks out of the cavity, blew around the sparkplugs before starting to loosen them, some loose grit came flying out with several blows in the small plastic tube, and also before the sparkplugs were completely removed some more loose stuff was "blown away", the second lot surprised me but there it is, easy to overlook this debris.
[Image: 83199e098d02fef42348dfdc8b210244.jpg]
and here are the plugs after 70.000 Km, the gap is 1 mm., the spec is 0.8 to 0,9 mm and i think i have gapped them before around 25.000 Km.
To me it seems fine for another 30.000 at least;
[Image: 2a9a6f1a999987dff24a2c77e405e94f.jpg]
and the tools i used to get them out and i used the smalles amount of 90w gear oil on the threads which helped a lot when putting them back in the engine, we"ll see if that was a good idea some time later;
[Image: be8138af8a672eccf9b3b5ae6dea6d2c.jpg]
So we think that removing them has some risk included because of the debris our bikes are prone to collect and it is easy to forget to blow the plugs clean before removing them, hope this helps.
The plugs look good to me too, max. 100,000 kms should be reasonable.
Yeah, the classic roadway debris is always an issue when removing plugs from any engine. Even if the high tension leads have rubber boot/caps, I still find junk tends to fall down into the base area of the plug.
Hmmm...and to think the shop where I had my valves checked also replaced the spark plugs at 14k miles.
I replace mine (and the air cleaner) approx every 25,000 miles (40,000km). Just put in my third set just before the CB 1100 rally this year.
I replace my spark plugs and air filter, all OEM, every 50K kms.
They always look almost like new.
For the Honda Africa Twin, over 100,000 kms. Some sort of [newer gen] iridium is used.
Very sure my plugs would last 100K+ kms, and the reason I dont keep them that long in service is air cooled engine and higher chance of failure, which I don’t need during long distance rides,
Biker
  NGK spark plug options Jonnyteabag_imp 6 608 08-05-2026, 11:35 PM
Last Post: JRD
  'Factory' high performance spark plugs PowerDubs_imp 17 1,469 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 551 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 326 06-27-2023, 01:19 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,120 06-24-2023, 08:27 AM
  spark plug caps alexzanutto_imp 3 388 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 771 10-08-2022, 12:22 PM
  Spark Plugs HondaJon_imp 105 6,940 03-19-2022, 08:53 AM
  CB 900C Custom Spark Issue goatman64_imp 3 357 11-27-2021, 07:11 AM
  Strength to tighten the spark plugs. syncronizator_imp 27 2,936 01-07-2020, 06:53 AM
