Torque Specs for fuel pump
After switching tanks (black to red) and installing a new pump in the new tank I have a very small leak near the rear of the pump close to the vent tube.
Does anyone have access to the torque specs for those 6 nuts holding the fuel pump gasket against the bottom of the tank
thanks
(03-13-2018, 01:39 AM)Mscb1100_imp Wrote: After switching tanks (black to red) and installing a new pump in the new tank I have a very small leak near the rear of the pump close to the vent tube.
thanks
The manual says 9 lb/ft... did you use a new gasket?
Used old one as it appeared very pliable,
Guess I’ll order 2 new ones as I don’t usually carry a fire extinguisher with me
Thanks for the torgue specs
My next purchase should be a service manual
(03-13-2018, 01:59 AM)Mscb1100_imp Wrote: Used old one as it appeared very pliable,
No problem!
I swapped tanks recently too and used a new gasket and followed the manual's procedure for torquing in a crisscross pattern (like lug nuts). However, I don't think the new packing/gasket is a necessity if the old one is pliable. If you're sure the leak is coming from the pump, maybe try re-seating everything and torquing again in the correct pattern.
I also used a new rubber insert and plastic clip for the fuel line... I think replacing these are really important to ensure you don't have any leaks from the connector.
Oh, the new manual you can get through Helm Inc. or your dealer includes all model years which is nice too....
No problem!
No problem!
Thanks Fly
I switched back to original tank gasket and did the criss cross earlier today when I discovered the leak before posting about the torque specs, (and it leaked also)
so I hope using the correct specs will work.
With the tank bottom side up a thin stream leaks out of the rear near the vent tube when I tilt it upward.
Greenish color male/female gas line connection is bone dry.
PS I ordered the service manual on line
You're welcome...
Sounds like it could be the gasket that's the issue. They way it's slotted and shaped on the edge may make it less effective if reused. Hopefully it's a quick fix for you.
  Fuel pump, yes really. GUNFTR_imp 13 1,122 01-02-2024, 01:11 AM
Last Post: SportsterDoc
  Fuel Pump Alternatives SamWhited_imp 13 1,025 07-11-2023, 08:52 PM
Last Post: The Gecko_imp
  Torque value question Jonnyteabag_imp 9 640 03-10-2023, 01:00 AM
Last Post: 1973cb750
  Fuel pump noise? Ben70_imp 15 985 07-16-2022, 12:22 AM
  fuel pump automotive equivalent battaglioa01_imp 0 193 11-19-2021, 02:11 AM
Last Post: battaglioa01_imp
  fuel pump whine battaglioa01_imp 2 341 11-18-2021, 05:30 PM
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 642 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 394 04-03-2021, 01:35 AM
  Bad fuel pump- jdgrego1_imp 33 2,413 11-20-2020, 03:07 AM
  Engine mount bolt torque value TCinNC_imp 43 2,539 07-31-2020, 05:00 PM
Last Post: treedoc_imp
