Odd Throttle Clicking When Accelerating or Decelerating
Does anyone else notice a clicking sound/feeling in the throttle when it is accelerated 1/4 in, then also when decelerating too?
Only happens when the bike is running and the throttle is moved slowly. I figure it could be something to do with the fuel injection system since it only happens when running? I’ve tried adjusting the throttle cables/positions on housing, lubing cables/housing, and tightening housing to no luck.
Just kind of annoying when riding. Wondering if anyone else has experienced it/mended. 2015 standard model.
Thanks folks.
I never heard this sound but of course I am slowing getting deaf....
You can feel a clicking through the throttle grip itself? Does it change in frequency with the speed of the bike? There is a sound that accompanies the clicking feel?
There are two throttle cables (one for positive close as a safety feature) that work the butterflies, in addition to a return spring that works to close the throttles. There is a throttle position sensor on the left side of the throttle body bank to measure the angle of the butterflies, but it has no motors or servos that could introduce a vibration or sound.
I wonder if something is contacting one of the cables along their route and transmitting some vibration. Weird, for sure, that it only happens when the throttle position is changing.
Those cables run through a cutout in the engine heat shield that sits above the cylinder head. Has the heat shield been off for a valve clearance check or something else? I suspect if the cables aren't routed properly, something could be contacting them.
Also check that both cables are captured properly in the little stay hook near the right side of the steering head.
--Joe
(09-27-2020, 12:17 PM)LakeWylieJoe_imp Wrote: You can feel a clicking through the throttle grip itself? Does it change in frequency with the speed of the bike? There is a sound that accompanies the clicking feel?
--Joe
Bike only has 900 miles on it so nothing has been taken apart, but maybe was put together incorrectly when taken out of the crate. I’ll take a look if I ever pull the tank off. Thank you for you advice.
(09-27-2020, 11:14 AM)codyp1814_imp Wrote: Does anyone else notice a clicking sound/feeling in the throttle when it is accelerated 1/4 in, then also when decelerating too?
Thanks folks.
Cody i would check if something is catching on or interfering with the throttle body cable segment on the throttle body, where the cable connects with the round segment when operated against the return spring, sounds like a unique case, and maybe you find that missing socket they lost in the factory......
(09-27-2020, 07:14 PM)max_imp Wrote: Cody i would check if something is catching on or interfering with the throttle body cable segment on the throttle body, where the cable connects with the round segment when operated against the return spring, sounds like a unique case, and maybe you find that missing socket they lost in the factory......
I figured it would be unique, just my luck haha. Thank you for the tip. I’ll try to see if I can access that without removing the tank. Difficult because it only happens when the engine is operating too.
Frayed cable?
Any update on this? I just got my RS bike second handed with 1125 kms on the odo. I started to notice exactly the same as Cody's observation.
Please advise if there is any effect on the operation of the machine.
Thank you in advance.
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,577 10-14-2025, 05:04 PM
Last Post: jikemenkins
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,357 10-11-2024, 04:53 AM
  Throttle cable exposed misterprofessionality 7 1,237 06-12-2024, 11:53 AM
  throttle operation The Gecko_imp 6 633 03-07-2024, 09:39 AM
  Throttle cable replacement Stoked907_imp 1 286 05-20-2022, 09:35 AM
  Throttle body sync? Whoops 6 582 07-10-2021, 02:22 AM
  Throttle Cable Replacement olekzap_imp 13 1,287 06-21-2021, 09:45 PM
  jerky throttle response... explained (video) jtopiso_imp 0 214 06-09-2021, 04:28 PM
Last Post: jtopiso_imp
   Ticking / clicking sound after oil change simplest2remember_imp 12 991 02-03-2021, 01:32 AM
  Throttle Cable oldgoat01_imp 7 1,054 01-15-2021, 06:33 PM
