LITHIUM BATTERY UPGRADE: Ballistic vs. Antigravity vs. Shorai
I'm working on a new mudguard design which calls for a minor relocation of the electronics under the seat and-you guessed it-coincidentally result in some weight savings, though not the main objective.
I'm gonna be ditching the stock Yuasa YTZ14S(before it fails me) in favor of a newer, smaller and lighter battery
I'm undecided between:
Ballistic Evo II 8-Cell 100-011
http://www.hardracing.com/ballisticlight...teries.htm
Antigravity AG-801 Lithium Battery
https://antigravitybatteries.com/product...se/ag-801/
Shorai LFX14A2-BS12
https://shoraipower.com/lfx14a2-bs12--p66
Open to all feedback/suggestions
Many Africa Twin owners use the Shorai, even though it is slightly underrated to OEM spec.
So far they appear content.
(03-15-2021, 06:16 AM)E11even_Hunnit_imp Wrote: I'm working on a new mudguard design which calls for a minor relocation of the electronics under the seat and-you guessed it-coincidentally result in some weight savings, though not the main objective.
Shorai LFX14A2-BS12
We were just doing some research for my buddies Octane and I discovered the climate you live in has alot to do with it. The lithium batteries do not like the cold. As much as I'd love a small battery tender powersport battery, the northeast won't treat it well over the winter. Even in my garage it gets very cold.
If you ride in a cold region and wish to use a lithium battery, you will need to turn on the ignition (headlight comes on), and wait up to 60 seconds. Allow the headlight to draw current and "warm up" the battery chemistry. After that, throw the start motor and the bike will crank to life.
Honda Africa Twin bikes 2018+ all have lithium batteries. Mine cranks no problem at -20C temperature.
(03-15-2021, 07:08 AM)GoldOxide_imp Wrote: Many Africa Twin owners use the Shorai, even though it is slightly underrated to OEM spec.
By slightly underrated? Are you referring to less CCA?
(03-15-2021, 07:47 AM)GoldOxide_imp Wrote: If you ride in a cold region and wish to use a lithium battery, you will need to turn on the ignition (headlight comes on), and wait up to 60 seconds. Allow the headlight to draw current and "warm up" the battery chemistry. After that, throw the start motor and the bike will crank to life.
Well thats good to now, my neighbor had an Africa Twin and had no issues.
Yessir.
So I ended up pulling the trigger on the Shorai. In the Bay area, you might see temperatures ranging from the 50's to the 80's(pretty broad range) for about 4 months out of the year, outside of that, it's mostly between 50's-60's for the greater part of the year. Coldest morning starts might occasionally be in the 40's in the winter.
I'll remember your advice on letting the Headlight wake it up prior to cold cranking
(03-16-2021, 02:42 AM)E11even_Hunnit_imp Wrote: So I ended up pulling the trigger on the Shorai. In the Bay area, you might see temperatures ranging from the 50's to the 80's(pretty broad range) for about 4 months out of the year, outside of that, it's mostly between 50's-60's for the greater part of the year. Coldest morning starts might occasionally be in the 40's in the winter.
Good to read. I suspect the CB1100 would have an easier time "warming up" the battery using the pre-2017 quartz headlight bulb.
I think some other Forum members have been using lithium batteries for a few years now and haven't reported an issue. Likely a good sign.
Don't forget to use a charger that has a lithium battery charge mode and ensure it actually goes into that mode if it tries to auto-detect lithium vs. lead acid.
Here's the Shorai (LFX14L2-BS12) standing side by side with the stock Yuasa YTZ14S for size comparison.
Although, it's rated slightly lower at 210 CCA, it's a mighty little battery. Cranks the bike no hesitation whatsoever, everytime.
[Image: 2ab81a30cf971061d5c5e8666515a645.jpg]
  ABS , speedometer and battery Walter 10 808 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,649 04-01-2026, 04:44 AM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,308 09-06-2025, 05:00 PM
  Rattle on right side exhaust / battery CB1100i_imp 4 699 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,134 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 297 08-01-2024, 02:33 AM
  Anyone ever use these Noco lithium Batteries? mvk24_imp 20 1,724 03-25-2024, 01:52 AM
  CB1100 fuel tank upgrade johnnyH_imp 3 454 03-13-2024, 01:31 AM
  wonder battery The Gecko_imp 58 4,754 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,281 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
