Yoshi install help
chrisross_imp Offline
Threads: 8
Yoshi install help
I just love in the instructions where it says "remove o2 sensor" as if that's not basically impossible without the right specialty socket.
Anyways, I'll figure that out. For the stop bracket, the instructions say to put the 2 rubber grommets (I think that's what they are called) on there...are those stock rubber grommets because my yoshi didn't come with any.
06-28-2014, 08:36 AM
Ridem32_imp Offline
Threads: 51
Yoshi install help
I got lucky and got a good used 02 sensor socket from a forum member. If you need it I can mail it to you for you to use.
06-28-2014, 08:52 AM
Threads: 8
Yoshi install help
(06-28-2014, 08:52 AM)Ridem32_imp Wrote: I got lucky and got a good used 02 sensor socket from a forum member. If you need it I can mail it to you for you to use.
Ridem, that'd be great!! I'll PM you.
06-28-2014, 09:28 AM
Greg_imp Offline
Threads: 8
RE: Yoshi install help
Hi Chris
You don't need to buy an expensive socket. I bought an inexpensive 17mm box end wrench and cut a 1/8" slot in it with a hacksaw. I selected a wrench that had a thin profile; the diameter of the end is about 1.03".
You don't have to use the O2 sensor. The Yoshi doesn't have a catalytic converter, which is the reason consumer EFI systems have an exhaust sensor. The ECU uses the signal from the O2 sensor to lean out the air fuel mixture to keep it in the 15:1 range. Richer ratios do not allow the cat to function properly and can shorten its life, even though the ratio for optimum engine performance is in the 12:1 to 13:1 range.
If the O2 sensor is bypassed with this inexpensive plug the air fuel ratio will drop from the 15:1 range to the 13:1 range. I know this because I did back-to-back dyno runs with and without the O2 sensor connected and can show charts of the different air fuel ratios. I did re-install the O2 sensor in my Yoshi exhaust but with it bypassed I can get 50 mpg, so the slightly richer fuel mixture is not costing me at the pump. You might also want to check out the threads on the PAIR valve mod. The PAIR valve introduces fresh air immediately after the exhaust port to enable additional combustion of any remaining unburned fuel. This combustion takes place in the exhaust headers and the fresh air also enhances the catalytic process in the cat, which begins functioning at 600°F.
These mods will allow your engine to run cooler, with less vibration and quicker response. There's no point to modifying the air intake. Any change you make to "open it up" will be immediately and easily compensated for by the ECU which is capable of maintaining consistent performance over a huge range of atmospheric pressures.
http://www.ebay.co.uk/itm/Oxygen-o2-sens...1215348991
Did you get a steel bracket to replace the center stand stop? It comes with a bunch of little parts, including 2 big rubber grommets, that should be shown in the installation instructions.
06-28-2014, 09:42 AM
Dengie Boy_imp Offline
Threads: 0
Re: Yoshi install help
This is really good info Greg. I was unsure how to go about bypassing the O2 lambda sensor.
EBay parts now ordered and on way from Greece Smile Thankyou
06-28-2014, 07:56 PM
  Windjammer ss. Install caddy425_imp 15 1,332 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,296 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,360 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Honda top case install Jonnyteabag_imp 11 905 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 638 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  Poking holes in a yoshi 3rdcoastcb1100_imp 6 563 06-24-2020, 05:19 PM
Last Post: treedoc_imp
  tail-bag install Chuckk_imp 6 612 11-19-2019, 05:49 AM
Last Post: IndianRider_imp
  Help! Dynojet PC V Install Not Going Well, 2014 CB MinkeyChief_imp 3 406 11-05-2019, 03:53 AM
Last Post: MinkeyChief_imp
  Left over part from TSR Intake and Funnel install?? teamvisegrip_imp 5 510 09-21-2019, 10:48 AM
Last Post: teamvisegrip_imp
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,288 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
