Fehling saddlebags support and signals relocation
VTR1000F_imp Offline
Threads: 13
Our friend [url=http://cb1100forum.com/forum/showthread.php?tid=1570]Barnattina brought to my attention German made Fehling saddlebag supports. I rushed to our shop today and as a miracle they had one kit on stock. I don´t understand that they hold this on stock as we have a very small number of CBs running. It cost me around 80USD and I can use them with my Kijima grab bar. The purchase will be logical for European based CBers as it is not needed to buy this from japanese manufacturers.
The kit contains solid-but-not so nice metal holder for relocation of rear turn signals to similar position as Hepco Becker. The supports are nicely made with spotless chrome. The kit contains plastic blanking plugs for the original position of rear turn signals.
Now I´m just waiting for Romo1961´s [url=http://cb1100forum.com/forum/showthread.php?tid=2528]wonderful relocation kit.
One question. What exact type of connectors do rear turn signal use? I would like to get some for the case Romo will not offer the kit with wiring pigtails. Thumbs Up
05-21-2014, 10:45 PM
Likes Received: 616 in 276 posts
Likes Given: 788
RE: Fehling saddlebags support and signals relocation
I believe if you look in Romos thread, VFR Paul listed type and retailer of the correct size connectors for the CB
05-21-2014, 10:57 PM
Threads: 13
Thanks, I´m aware of this:
http://www.cycleterminal.com/050-connectors.html
Does the CB use "HB" or "HC" connectors? I´m not with my bike today and tomorrow so I can´t take a look.
Thank you.
05-21-2014, 11:07 PM
Threads: 13
I finally got to install of the saddlebags support and ran into a problem. They can´t be installed without relolocation of the indicators. Rear bracket with thru-bolt is too long and collides with indicator chrome housing.
For those who already relocated their signals - what is the cleanest approach? Disconnect them under battery tray (where the connectors are located I suppose), and put some kind of pigtails between original indicator loom and main loom? Or disconnect the wiring inside the indicator housings and go from there?
I´m coming from VW Beetle world and I´ve seen all kind of mechanical and electrical hacks on these poor cars..I like to keep everything factory looking or at least returnable to factory condition.
Thank you!
06-02-2014, 03:39 AM
Honda4Ed_imp Offline
Threads: 3
I like the Fehling products shown but it has so far been a hassle to procure and install. There are two products shown in the picture. The "luggage carrier" is the top rack that extends over the tail light and the "baggage holder" which is the U shaped tubing on both sides. They are sold separately and the 2013 luggage carrier does not fit the 2014. If fact it is in redesign and when available it will be made to fit either the 2013 or 2014. You can find these products at the Fehling.de website. Note that the turn signal relo hardware is included with the "baggage holder".
Regarding the turn signals I have decided to remove the originals (which come out all the way from the connectors near the battery) and replace them with the smaller but brighter X-Arc Yellow Chrome which can be found here: http://www.hightechspeed.com/products/XArc/index.asp
I found replacement orange and blue connectors that will allow me to keep the original turn signals with the wiring in the event I ever want to put them back. They can be spliced ot my new signals and can be found here: http://japan.webike.net/products/21125590.html
08-26-2014, 09:21 AM
  saddle bag support pdedse 15 1,695 06-26-2025, 03:18 PM
Last Post: Whoops
  Fehling crash bars Newceebee_imp 13 1,013 02-03-2025, 11:47 PM
  LED Turn Signals deuce17EX 23 2,377 03-12-2024, 10:58 AM
  Canvas saddlebags syncronizator_imp 15 1,110 12-26-2023, 02:43 AM
  LED turn signals Elipten_imp 32 2,436 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 674 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 675 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 374 11-11-2021, 09:23 PM
  Turn Signal Relocation Cormanus 11 917 12-30-2020, 11:12 AM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 816 05-20-2020, 09:58 PM
Last Post: Richard_imp
