Spark Plugs
#71
Hopefully any foreign matter that may have gotten into the cylinder was simply expelled versus doing any damage.
(12-17-2020, 10:13 PM)tod.branko_imp Wrote:
(12-17-2020, 02:06 PM)Alfgaxatico_imp Wrote: My friend ; how many time/kilómeters was from the last change ????
I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000km
'14 CB1100 STD 5 speed
I've replaced my plugs on my CB1100 twice, each time at around 40,000 KM's (25,000 mi)
I currently have 36,000 miles (58,000 kms ) on the plugs on my FJR and they will be changed next month
I currently have 36,000 miles (58,000 kms ) on the plugs on my FJR and they will be changed next month The bike was running perfectly, but the plugs were very corroded on the outside and I didn't want to have problems with taking them out in future, I'm sure these will last for a very long time.
Good call Tod, would have done the same when my plugs looked like that, saltspray has a bad effect on these, mine have a little corrosion but are still ok at 40.000k.
Interesting the airfilter, do you find it dusty in the Emirates?
Nice clear pictures too, thanks mate
(12-16-2020, 11:09 PM)tod.branko_imp Wrote: Yup, thanks, all done, I removed the tank for sake of it, as it turns out I even had a special tool [Image: 8cf6fe798eb7be7eb00c341ea64a99eb.png]
Anyhow, thank you for the tip, I actually only disconnected the quick connector and turned the tank around counterclockwise on the seat.
Air element was a hassle, stuff that is under my right side cover looks nothing like the workshop manual picture. Off to put in fork gaters. That's for a different thread tho[Image: 7c163879a744afa8b7793b4bfa247f80.jpg][Image: 2f3e37a2cf8d96edd4341f31d1b0110b.jpg][Image: b2c445d66562217bc97184f7c456ebc9.jpg][Image: bd33dd11d2938e441a772541a6cee685.jpg][Image: 191fb6ff4cb31ded45c35766aab8cdf2.jpg]
@tod
Any chance you could make a little sketch on "turning the tank ... on the seat" ? (thanks for the nice pictures !)
(12-18-2020, 07:18 PM)max_imp Wrote: Good call Tod, would have done the same when my plugs looked like that, saltspray has a bad effect on these, mine have a little corrosion but are still ok at 40.000k.
Extremely dusty and humid
@tod
@tod
Any chance you could make a little sketch on "turning the tank ... on the seat" ? (thanks for the nice pictures !) And sure, I will be happy to. Hope it helps.[Image: 1443cd9c4d4df13193c2dae5bf181111.jpg]
And this can be done without disconnecting the fuel pump ? Or am I missing sth ?
@tod
@tod
This looks like the start of sumthin' big. Tongue
(What is "Adam"?) Big Grin
It was a 30 seconds sketch. I guess the paper is transparent, not an issue, no top secret stuff there [Image: 4d436a198a1d219498dfc84baf3bc01f.png]
(12-19-2020, 12:01 AM)tod.branko_imp Wrote: It was a 30 seconds sketch. I guess the paper is transparent, not an issue, no top secret stuff there [Image: 4d436a198a1d219498dfc84baf3bc01f.png]
Dang. No clay model coming?
  NGK spark plug options Jonnyteabag_imp 7 672 10 hours ago
Last Post: SportsterDoc
  spark plugs after 70.000 Km DAC 16 1,637 12-23-2025, 10:15 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,510 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 581 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 340 06-27-2023, 01:19 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,235 06-24-2023, 08:27 AM
  spark plug caps alexzanutto_imp 3 420 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 798 10-08-2022, 12:22 PM
  CB 900C Custom Spark Issue goatman64_imp 3 384 11-27-2021, 07:11 AM
  Strength to tighten the spark plugs. syncronizator_imp 27 3,111 01-07-2020, 06:53 AM
