Chain Lube
#51
(06-20-2019, 01:21 AM)Nortoon_imp Wrote: I am surprized he used Maxima Chain Wax which is nothing more than paraffin. They sell Tirox Synthetic Chain Wax which is slightly less expensive for a large spray can. Fort Nine is one of the few place you can buy it, unless you want to pay 3 times as much on Amazon.
According to the spray can print Tirox utilizes a proprietary two-stage chemical and electrical charge process joining nano-synthetics with a PTFE infusion, virtually eliminating chain and sprocket wear.
I use Tirox Synthetic Chain Wax and find that it does not fling or gather a lot of grit. That keeps the chain, chain guard, rear wheel spokes and rim much cleaner than anything else I have tried.
The warning information is scary, and to back it up a pair of nitrile safety gloves come stuffed in the cap.
I've been using Tirox for a few years now. Every time I leave home a mile of very sandy dirt road is part of my ride, coming and going. Over the years many different chain lubes have been tried and Tirox is best at staying on the chain and not picking up sand and forming an abrasive paste. It also cleans up easily with a rag and some WD-40.
I wouldn't want to inhale any of that either. Who knows what the price will be 10 or 15 years later. Undecided
(I'm sorry if this is a bit lengthy.)
Because the bearing surfaces of modern chains are sealed and protected by the 'O' or 'X'-rings, we're really only talking about the exposed surfaces of the chain needing protection from the atmosphere. It seems to me, therefore, that actual "lubrication" is totally unnecessary - only protecting the exposed surfaces from rusting is all that's required. I mean, if 'O' or 'X'-rings seal manufacturer's grease IN, how do externally applied products miraculously get past them to add lubrication. I believe claims of "lubrication" to be mostly snake-oil and the profits of these companies are on the back wheels of motorcycles, a bit like Heinz' profits being from what's left on the edge of your plate!
As others have noted, a regular wipe with an oily rag is all that's needed to achieve prevention of rust, because a rusted surface will eventually creep under the 'O' or 'X'-rings and damage their ability to seal the manufacturer's grease in.
So, if you accept that modern chains don't need actual additional "lubrication", then a non-flinging coating on the rest of the chain could be all that's required.
We have a product here in the UK, 'ACF-50'. It's an aerosol light oil, "stickier" than ordinary oil, and is intended to winter-proof motorcycles against the effects of water/road salt spray/etc. and it needs regular applications throughout the winter. It seemed to me that this could be all that's needed to protect chains. It's not a lubricant per se, but a protectant. It would need several applications throughout the year, more often in winter. It's not as "overkill" as I believe many (expensive!) products are, but not as tedious as constant wiping with the proverbial oily rag. A quick spray every 500 or 1,000 miles, whenever, could be all that's needed. (I don't believe ACF-50 Grease to be suitable.)
With this in mind, I wrote to ACF-50 and asked them their experience with "chains". This is their Product Manager's reply...
"Thanks for your enquiry.
We have racing motorcyclists who use nothing except ACF-50 on drive chains ! – when I queried this with a couple of them the reason was obvious.
They could spin the rear wheel with chain in place – and the resistance was minimal, plus they chucked the chain away after every meeting.
 However – for everyday riding of course you need the proper lubrication provided by the wide range of chain lube choices available these days.
ACF-50 has its place for use on the side plates as you mentioned – it’s not harmful to chain o-rings.
The Corrosion Block grease ( made by same manf as ACF-50) does not have the same creeping properties as the liquid for obvious reasons – and to be honest, we have no experience of its use as a “protector” on motorcycle chains – but it might work ok as long as not too heavily applied so as to avoid “fling”.
Some years back the Scotoiler people got close to adding ACF-50 into their chainlube system – so there is no reason why you could not apply it along with regular chain products – but definitely not on its own.
Hope that helps.
Best Regards
Dave
Dave Heppell
Product Manager"
Confusingly, he says "you need the proper lubrication provided by the wide range of chain lube choices" which is the very thing that I take issue with - I don't believe "lubrication" to be the issue with our chains. But other than that, it seems that ACF-50 is a good substitute for "the oily rag".
Smile
I always felt the same as you do, if the chains are sealed than we just have to prevent the rusting of the side plates. The "silver" plated DID ZVM-X chains does not rust as the "normal" chains do.
Thanks, John. I've not heard of DID's ZVM-X chain (but as a BMW rider that's not surprising!). If they do not rust, that is almost all the battle won, in my opinion. Light lubrication of the edges and surfaces of 'O' and 'X'-rings, to stop drying out, is probably all that's then required?
I use an oily rag with 80/90 gear oil on it. Cheap and cheerful .
I, too, have a DID ZVM-X now and i can corroborate the accounts above. It's just the best choice for a new chain when you need one. that said, the OEM chain goes for stupidly long miles compared to some. in case nobody else has posted it, here's some "science" on chain lubes for you to consider:
https://www.youtube.com/watch?v=VnPYdcbcAe0
I’m sure I’ve seen that video somewhere. Confused
After watching the video and reading the owner's manual, I'm convinced that gear oil is the best solution. However, I will continue to use Maxima chain wax because I like the way it smells. Seems as good a reason as any. Smile
Sometime in the future, I may switch to gear oil and keep some chain wax around as an "air-freshener" for my garage.
When I picked up my 2013 CB/demo-4500km, the chained was lightly greased...
  Oinker Chain Lube Tool Gone in 60 4 478 01-15-2025, 08:31 PM
  Lube chain with chainsaw oil mrded_imp 43 2,873 06-01-2022, 01:20 AM
  Preferred chain lube? 2014ltdltz 19 1,353 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 990 11-19-2019, 12:57 PM
  Chain Lube Type and Frequency? Nappi185_imp 29 1,800 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 993 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 375 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,159 05-01-2015, 09:03 PM
  Chain lube frequency? Michael252_imp 41 2,565 02-13-2014, 10:52 AM
Last Post: ride4now_imp
