Chain lube frequency?
Hey guys, maybe you can help with this.
Assuming "normal" riding conditions (normal in this case means no riding in the rain or no dusty dirt roads), how often do you apply chain lube?
Thanks
Me about every 500 miles, but I don't ride in dirt or rain if I can help it. If I did that would require cleaning and extra lubing. Just turned over 1300 miles, lubed for second time with BelRay Super Clean chain lube after my ride yesterday.
I got 30,000 miles out of my last 530 oring chain.
(06-02-2013, 11:46 PM)The ferret_imp Wrote: Me about every 500 miles, but I don't ride in dirt or rain if I can help it. If I did that would require cleaning and extra lubing. Just turned over 1300 miles, lubed for second time with BelRay Super Clean chain lube after my ride yesterday.
+1
I do about 10% riding on dirt and gravel and got caught out in a thunderstorm yesterday.
Question - how best to clean the chain? Power washer on low setting/ several inches from the chain so as not to damage anything?
(06-03-2013, 01:05 AM)CB4ME_imp Wrote: I do about 10% riding on dirt and gravel and got caught out in a thunderstorm yesterday.
I used to wet a rag with kerosene and wipe the chain the best I could. I'm probably being paranoid but I'd be afraid that using a power washer, even on low, would push dirt down into the links and past the o rings.
I don't know that kerosene is the best bet for the o-rings.
(06-03-2013, 02:06 AM)Randy B_imp Wrote: I don't know that kerosene is the best bet for the o-rings.
Oops. I don't know why I said kerosene. I meant to say oil with just enough gasoline mixed in to cut through the gunk.
Thanks, everyone. I'm about to turn 600 miles, so I guess I'll break out the ol' spray can.
I thought kerosene works pretty good.
It's not a bad degreaser, but it will eat up the O-rings and drastically shorten the life of the chain.
  Oinker Chain Lube Tool Gone in 60 4 472 01-15-2025, 08:31 PM
  Frequency of chain oiling? Rebel73_imp 48 3,450 09-28-2023, 05:55 AM
  Lube chain with chainsaw oil mrded_imp 43 2,857 06-01-2022, 01:20 AM
  Preferred chain lube? 2014ltdltz 19 1,343 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 988 11-19-2019, 12:57 PM
  Chain Lube Cormanus 68 4,259 07-22-2019, 07:54 AM
  Chain Lube Type and Frequency? Nappi185_imp 29 1,795 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 992 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 373 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,156 05-01-2015, 09:03 PM
