Preferred chain lube?
What is everyone using for chain lube? Chain wax? In the past I have used 20W50 Mobil 1 (applied judiciously, of course).
I've just discovered and bought some 'ZX1' Lubricant.
This is what they say about "chain oiling"...
"As for the chain, most bikers initially heat treat the chain with ZX1 then use the C60 spray regularly to keep it in good shape, one of the benefits is stopping chain stretch
If you go down the route of heat treating the best way is to heat a small container of ZX1 in a pot of boiling water, make sure the area is well ventilated, and paint it onto the chain or better still if you can do it is to immerse the chain."
Not tried it yet, but I know that the amazing Allen Millyard uses it, and that's good enough for me!
https://youtube.com/c/AllenMillyard
"X1 Lubricant Oil" http://x1oil.com
and... here we go!
(05-20-2022, 12:39 AM)Lord Popgun_imp Wrote: and... here we go!
ROFL
You should find a few references to chain lube on the SEARCH function in the upper left of your screen.
There are almost as many preferences for chain treatments as there are CB1100s.
Have fun.
Lubricating the chain iz, ... good.
But what with Big GrinBig Grin
Heat treat? Lubricant that stops chain stretch? This stuff sound like snake oil to me.
I am with MiLord
(05-20-2022, 04:26 AM)Dave_imp Wrote: "As for the chain, most bikers initially heat treat the chain with ZX1 then use the C60 spray regularly to keep it in good shape, one of the benefits is stopping chain stretch
I've never had to replace a drive chain. Then again, I hate chains.
That said, I just use a Tutoro auto-luber and forget 'bout it.
Maxima chain wax. Been using it for about 15 years and never had to replace a chain before due to wear.
Perhaps because I'm very OCD and ride like a girl....
  Oinker Chain Lube Tool Gone in 60 4 515 01-15-2025, 08:31 PM
  Lube chain with chainsaw oil mrded_imp 43 3,016 06-01-2022, 01:20 AM
  chain lube.. "fluid film" Chuckk_imp 14 1,012 11-19-2019, 12:57 PM
  Chain Lube Cormanus 68 4,367 07-22-2019, 07:54 AM
  Chain Lube Type and Frequency? Nappi185_imp 29 1,870 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 1,008 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 380 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,197 05-01-2015, 09:03 PM
  Chain lube frequency? Michael252_imp 41 2,715 02-13-2014, 10:52 AM
Last Post: ride4now_imp
