07-31-2020, 09:44 AM
I know, it may sound weird, however, I know people doing that. And they found it very good.
What do you think?
What do you think?
Lube chain with chainsaw oil
What do you think?
07-31-2020, 10:12 AM
The lubrication would probably be good, but the splatter mess would not be fun to clean up
07-31-2020, 10:47 AM
I'd have to ask why? They formulate perfectly good lubes made specifically for motorcycle o ring chains in easy to apply aerosol cans for very reasonable prices. Most will only lube a chain a few times a year, even if they ride a lot.
07-31-2020, 11:10 AM
My dad lives in Kazakhstan, travels a lot on his Africa Twin. it’s him who initial recommended it to me.
Over the time he found it as the most convenient way to lube a chain. He always travels with 300mils bottle of chainsaw oil and a toothbrush. As he said, It would last him for about 20k miles. I can ask him more, if you’re interested.
07-31-2020, 11:45 AM
That's interesting. There was a forum member who used to carry a small bottle of some kind of lube (80 wt gear oil maybe?) and a small paint brush. If IRC he used to brush it on about every 300 miles,
07-31-2020, 02:19 PM
FortNine's comparison video recommends gear oil. How different is that from chainsaw oil, I wonder?
07-31-2020, 04:56 PM
I use bar oil to lube my chain. It is a lot 'stickier' than gear oil, and is designed to lube saw chains without flinging off everywhere.
I clean the chain on the center stand, rotate the wheel while I apply bar oil, then wipe off excess with a rag. Works for me. I buy bar oil in 20l drums, so I usually have some around!
07-31-2020, 06:27 PM
Interesting point about the bar oil treedoc, i use gearoil 85w hypoid with a 50% petrol mix to wick it into the rollers better.
Reason for the gear oil is indeed the ability to stick to metal and i also wipe off any excess on the side of the chain. Freely admit to not knowing bar oil properties would you say that it sticks more than the hypoid i use now? If so i could be tempted to try it out at least, like to know your thoughts on that........
07-31-2020, 07:22 PM
Honestly Max, I have no idea!
I am far from an oil expert, but my understanding is that bar oil has additives to make it tacky. I mostly use it because I have a ready supply, and hold a generally vague and uninformed belief that its probably not much different from motorbike chain oil... Sorry I couldn't be more helpful lol
07-31-2020, 07:35 PM
Cheers Doc, the quantity you hold got my attention and combined with your username got me thinking, i will keep snooping around for some product, there are some magic lubricants out there, someone called "rawze" pulled his cummins diesel at 1 million miles and the liners still had most of the crosshatching in them, bearings and rings looked nearly new, apart from his excellent drive style he mentioned; i add a gallon of gearlube to the oil each oilchange..... i like the test with the nail in the jar at the end;
https://www.youtube.com/watch?v=pOdyRQU56Q0 Probably not available in nz though, appreciate your comments mate, hoping for a little bit of sun soon, have fun. |
« Next Oldest | Next Newest »
| Oinker Chain Lube Tool | Gone in 60 | 4 | 471 |
01-15-2025, 08:31 PM Last Post: Cormanus |
| Preferred chain lube? | 2014ltdltz | 19 | 1,341 |
05-23-2022, 12:17 PM Last Post: rboe |
| chain lube.. "fluid film" | Chuckk_imp | 14 | 988 |
11-19-2019, 12:57 PM Last Post: GoldOxide_imp |
| Chain Lube | Cormanus | 68 | 4,257 |
07-22-2019, 07:54 AM Last Post: GoldOxide_imp |
| Chain Lube Type and Frequency? | Nappi185_imp | 29 | 1,794 |
09-02-2017, 05:10 AM Last Post: Nortoon_imp |
| Grease Ninja - chain lube applicator | Huladog_imp | 14 | 990 |
01-05-2016, 12:39 AM Last Post: Motogeezer1949_imp |
| OEM chain Lube? | Inhouse Bob | 4 | 372 |
12-30-2015, 02:30 PM Last Post: TINK_imp |
| DLX chain lube technique | DJS_imp | 18 | 1,156 |
05-01-2015, 09:03 PM Last Post: the Ferret |
| Chain lube frequency? | Michael252_imp | 41 | 2,516 |
02-13-2014, 10:52 AM Last Post: ride4now_imp |
