Chain Lube Type and Frequency?
Hi Guys, New CB1100EX owner here. I see that much like motor oil, there are countless different brands and types of chain lube on the market. I see chain lube, chain wax, etc., etc. Any advice on what to use and how often to apply it. I assume it is just as simple as it would seem: Put it up on the center stand and spin the rear wheel slowly while spraying it directly on the chain? Thanks, Nappi
Congrats on your new CB and welcome! Everyone has their own opinions and preferences, but if you wanted trusted guidance without any added anxiety, simply use Pro Honda Chain Lube (either Moly or White Graphite) and follow the application directions in your owner's manual. There's nothing wrong with that.
I have tried the pro Honda stuff and prefer the Original Bike Spirits white graphite version better. It is a bit thicker and stays on better. I use the Ferret method:. Put it on the center stand, turn the bike on and put it in first and hit the side plates and rollers as they go by. Use the little plastic tube that comes with the can and watch ur fingers.
see this:
http://cb1100forum.com/forum/showthread....#pid180538
(As I said there - I would not tell anyone else what to do, I'm only telling you what I do. It may well be the case of an advice worth exactly what you paid for it Smile
I've tried it all and I'm sticking with PJ1 Blue Label.
[ul] [li]Low fling[/li] [li]Long-lasting[/li] [li]Minimizes dirt accumulation[/li] [li]Prevents rust (especially in the presence of salt on roads)
[/li][/ul]
I'm not a fan of the "goes on wet then dries" lubes because they don't prevent rust.
Chain cleaner that I use (keep plenty on hand) is Maxima Clean Up Chain Cleaner.
[Image: 219cf7e8bbf42171d1a1ea4dfe76fc32.jpg]
The Tirox 360 [url=https://www.revzilla.com/motorcycle/tirox-360-chain-brush]chain brush works very well.
[Image: 13170148d0e6beef0d112c5592dcce2c.jpg]
New Hondas come with the chains lubed with what looks like a white grease of some sort. I like the way it looks which I know is not the important thing, but if it does its job, then maybe I'd try using it. Trouble is that my dealer uses the Pro Honda lube which is not the same stuff. So, anyone know what Honda uses, how difficult it is to apply, and/or where I can buy it?
Might be [url=https://www.amazon.com/WD-40-Specialist-Protective-Lithium-Grease/dp/B0083V8KBE]white lithium grease, Mike. Just a guess though.
Ferret uses stuff that goes on white. It looks OE. I forget what it is.
I got some free chain lube from Repsol several years ago and after using up that small can I bought more of it because it's good stuff. It's easy to get just enough of it on the chain and it doesn't fling off.
Bel Ray Super Clean
  Oinker Chain Lube Tool Gone in 60 4 470 01-15-2025, 08:31 PM
  Frequency of chain oiling? Rebel73_imp 48 3,448 09-28-2023, 05:55 AM
  2017 tube type tires Mafd2_imp 4 473 02-08-2023, 01:10 PM
  Lube chain with chainsaw oil mrded_imp 43 2,849 06-01-2022, 01:20 AM
  Preferred chain lube? 2014ltdltz 19 1,338 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 988 11-19-2019, 12:57 PM
  Chain Lube Cormanus 68 4,252 07-22-2019, 07:54 AM
  Type of fuel injection system? dave 3 330 02-09-2019, 04:12 AM
  Grease Ninja - chain lube applicator Huladog_imp 14 981 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 371 12-30-2015, 02:30 PM
Last Post: TINK_imp
