Josh’s bigger throttle bodies project
#51
When measuring the ID of the stock throttle body casting directly, the bores are roughly 30.5mm at the exit. When measuring the ID of the stock intake funnels, they taper to a minor diameter of ~25mm before beginning to taper open again, expanding to roughly 30.5mm.
After exploring several other Honda intake funnels and also some aftermarket options I determined that boring the ID of the stock funnels very nearly maximizes what is possible when attempting to increase intake cross-sectional area via different or modified intake funnels. Whether it be done via a sandpaper drum or flap-wheel, or more sophisticated methods, opening the stock intake funnels to roughly 30.5mm buys you all the intake area that you can possibly achieve with the stock throttle bodies.
To anyone who would attempt such a modification, be aware that at a 30.5mm ID bore, the walls of the stock intake funnels will taper down to ~1mm (.040") wall thickness.
2017 CB1100EX #0288
2024 Z900RS SE #4222
1971 CB175
  Throttle cable exposed misterprofessionality 7 1,193 06-12-2024, 11:53 AM
  throttle operation The Gecko_imp 6 588 03-07-2024, 09:39 AM
  Throttle cable replacement Stoked907_imp 1 272 05-20-2022, 09:35 AM
  Throttle body sync? Whoops 6 538 07-10-2021, 02:22 AM
  Throttle Cable Replacement olekzap_imp 13 1,170 06-21-2021, 09:45 PM
  jerky throttle response... explained (video) jtopiso_imp 0 204 06-09-2021, 04:28 PM
Last Post: jtopiso_imp
  Odd Throttle Clicking When Accelerating or Decelerating codyp1814_imp 7 710 01-29-2021, 01:04 AM
Last Post: supruet_imp
  Throttle Cable oldgoat01_imp 7 1,042 01-15-2021, 06:33 PM
  Healtech eSync tool- synchronize balance throttle bodies PowerDubs_imp 11 1,041 12-06-2020, 06:43 PM
  Brake lever gap from throttle. zirconxi_imp 16 1,246 10-25-2020, 06:26 PM
