Shinko 777 tires for my 2017 CB1100ex
#41
Houtman, while maybe cost is something Honda should consider, I’d have thought the thing they should really be sure of is that a range of tyres that fit the wheels is available.
While cost is always a consideration, a motorcycle manufacturer calls for a certain specification of what should work best when designing a bike, suppliers submit samples, they get tested and approved. They get installed on new bikes and a supply line is provided for those particular tires from those manufacturers as OEM replacements. That exact tire that the bike was designed for will be available from them.
Of course you can get cheaper/more expensive, better/worse tires in the same sizes. They can't control supply chains outside that. Tire manufacturers are always changing compounds/tread patterns/dimensions, or discontinuing/replacing a model or size.
A good example was a complaint of wobbling under certain conditions (like taking both hands off the bars!) on a touring bike when the OEM tire was replaced with the same brand/model/size from the aftermarket. The OEM replacements from the dealer didn't have that problem.
When you say “That exact tire that the bike was designed for will be available from them” does ‘them’ mean the bike manufacturer or the tyre manufacturer? My Honda dealer could not get either of the OEM tyres as replacements when I first tried. Or were they avaialable from the tyre manufacturer.
(01-29-2019, 05:53 AM)Cormanus_imp Wrote: When you say “That exact tire that the bike was designed for will be available from them” does ‘them’ mean the bike manufacturer or the tyre manufacturer? My Honda dealer could not get either of the OEM tyres as replacements when I first tried. Or were they avaialable from the tyre manufacturer.
In the US, it means order from the dealer who orders through Honda parts. At least that's how it's supposed to work, and I know there are often backorders.
For tire manufacturers, OEM motorcycle supply is only a small fraction compared to the aftermarket, and nothing compared to car needs.
Nobody likes to storehouse anything anymore, relying on last-minute replenishment. Tire manufacturers, like just about every supplier, have their schedules full for months in advance. An order of 500 tires has to be squeezed into their production schedules.
Thanks pekingduck.
(01-29-2019, 04:25 AM)pekingduck_imp Wrote: Chuckk, both rims on the 2017 CB1100EX have inner bead lips similar to those on tubeless cast rims that may help retain the tire on the rim. Don't know that they are identical or will function the same, so proceed at your own risk.
thanks duck ... I feel confident the tire will stay in place if I get a flat.. my biggest issue now, is fitting that 120/90/18 shinko777 under that front fender and having enough clearance to allow for expansion from centrifugal force and heat.. I will pull my front fender and see if there is any way to fudge on the clearance between the fender and tire.. wish me luck ..
Chuckk j.
Good luck Chuck.
(01-29-2019, 12:32 PM)GoldOxide_imp Wrote: Good luck Chuck.
thanks G.O. .. I took a brief look at that fender a few days ago .. It may not be too easy to raise it up .. but it would be great if I could find a way..
chuckk j.
chuckk j.
Is there even enough margin to raise it around the top of the lower fork component without going all custom?
chuckk j.
let me pull it and see what my little brain can come up with.. haha ..
chuck j.
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 904 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,151 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 875 10-09-2023, 07:51 AM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,149 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 646 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 554 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  2017 tube type tires Mafd2_imp 4 485 02-08-2023, 01:10 PM
  2017 CB1100EX Brake Bleeding M1tch_imp 1 300 03-05-2022, 04:29 PM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,087 07-19-2021, 08:28 AM
  2017 CB1100EX Dart Marlin Flyscreen TXBikerGuy 4 429 07-23-2020, 11:22 AM
Users browsing this thread: 13 Guest(s)
