2017 tube type tires
So, where are you guys getting your tube type 18" tires for the 2017? Any options or other brands? Thanks
Some members of '17EX converted their rims to tubeless and ditched the tubes forever.
Best option IMHO.
(02-08-2023, 06:54 AM)m in sc_imp Wrote: avons. or bt 46's
Are you running tubes in them or have your wheels sealed for tubeless tires?
A major topic at ADV forums.
Alain Lee here at the CB1100 Forum has a 2017 CB1100 model (or later?, ... I believe) and he has successfully converted his laced rims to tubeless using the Outex kit. His years of tours has been significant on the converted rims.
I also use the Outex kit on my spoked rims. So far so good.
Others have used the Outex kit too. Aussieflyer, for example.
Someone asked about this the other day and got advice that running tubes in tubeless tyres was fine.
See http://cb1100forum.com/forum/showthread.php?tid=18404
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 836 10-09-2023, 07:51 AM
  Fork tube rust melfl_imp 8 731 12-23-2022, 04:41 AM
Last Post: redbirds_imp
  Shinko 777 tires for my 2017 CB1100ex Chuckk_imp 314 24,440 12-14-2020, 02:42 AM
Last Post: jimgl3_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 672 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Fuel Tank overflow drain tube. zirconxi_imp 11 852 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  Throttle tube easy to fit? Buzzard Biker_imp 9 661 02-28-2020, 11:21 PM
Last Post: Bazbro_imp
  Type of fuel injection system? dave 3 330 02-09-2019, 04:12 AM
  Aluminum fork tube oxidation ? bflint 12 824 01-09-2019, 02:32 PM
  Outside lower fork tube diameter Mscb1100_imp 5 512 01-12-2018, 10:34 AM
Last Post: Aussieflyer
  Chain Lube Type and Frequency? Nappi185_imp 29 1,792 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
