Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels
I am wondering if it is possible to retrofit 2017 CB1100EX which comes with 18” spoke wheels from factory with pre-2017 18” cast wheels.
Tire sizes are difficult to find but having inner tubes is even harder.
(04-14-2021, 02:34 PM)supruet_imp Wrote: I am wondering if it is possible to retrofit 2017 CB1100EX which comes with 18” spoke wheels from factory with pre-2017 18” cast wheels.
Just because your 2017 EX has tubes does not mean you need a tube-type tire. You can run tubeless tires with a tube, and 2017 EX wire wheels can be converted to tubeless. http://cb1100forum.com/forum/showthread....t=tubeless
For US models at least, the 2013 wheels (silver with black spokes) had different size rear axles, and the wheel cannot be easily adapted. 2014 Standard (black wheels) and 2014 Deluxe (silver wheels) use the same size rear axles.
However, converting them is very expensive, and the rear wheel speed sensor is incompatible between 2014-2017. http://cb1100forum.com/forum/showthread.php?tid=15438
I swapped the cast wheels on my 2014 for the 2017 spoke wheels. So yes, it is possible. I still have the front cast wheel that I would sell pretty cheap if you'd like.
Old post but if OP was able to swap, I would buy spoke wheels
(05-21-2021, 01:45 AM)Jimbo_imp Wrote: I swapped the cast wheels on my 2014 for the 2017 spoke wheels. So yes, it is possible. I still have the front cast wheel that I would sell pretty cheap if you'd like.
Jimbo, just curious if your front wheel is a black or silver one?
Also, did you have any issues with the rear speed sensor?
I swapped my 2017 tank for a black 2014 one. Sounds like we went completely opposite ways, but both happy.
try emailing him pd (info available by clicking on his name). He hasn't been on the forum since Feb 9 of 2022
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 995 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,361 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  Question re: 2017EX spoke rims tubeless conversion slmjim n Z1BEBE_imp 6 609 10-28-2023, 09:24 PM
Last Post: slmjim n Z1BEBE_imp
  CB1100 EX tyres & wheels Ol' RedJ_imp 14 1,260 07-19-2023, 05:04 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,260 06-24-2023, 08:27 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 583 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Laced wheels ? ashishNJ_imp 3 402 02-08-2023, 01:09 PM
  How to remove both wheels? RandyBMC_imp 18 1,517 05-10-2022, 11:12 PM
Last Post: Tom_imp
  2017 CB1100EX Brake Bleeding M1tch_imp 1 304 03-05-2022, 04:29 PM
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,300 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
