2017 CB1100EX Dart Marlin Flyscreen
I'll take a better pic of the flyscreen on the bike outside whenever I'm able to get it back outside, but here are some pics showing what the Dart Marlin flyscreen looks like on the 2017 EX model.
Relatively easy install. Required:
1. Removing front of headlight
2. Disconnecting turn signal plugs (R=blue, L=orange)
3. Removing both headlight side brackets
4. Removing both turn signals
Removing the headlight brackets was a little tricky--not much room to fit the allen wrench up there--at least on the right side due to the brake line.
The new headlight mounting brackets push the entire headlight unit forward about an inch, maybe inch and a quarter. I don't really notice it.
Looks good to me, like its size Thumbs Up
Looks good. Let us know what the slipstream is like at speed after testing it out some. The airflow with no screen is smooth, but beats you up at speed. I'd be interested to know how much it helps.
If the top of the screen measures 10 1/2" or less from the ignition he should be fine. It should keep the wind off his chest, but not high enough to bobble his head.
GrahamT has found that a water bottle in a thick sock fits neatly between the "V" of the gauges and the Marlin screen.
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 887 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,068 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,121 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 635 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 548 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  2017 CB1100EX Brake Bleeding M1tch_imp 1 295 03-05-2022, 04:29 PM
  Honda cb1100 rs Dart windscreen Nico_imp 7 679 08-26-2021, 07:25 PM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,043 07-19-2021, 08:28 AM
  Shinko 777 tires for my 2017 CB1100ex Chuckk_imp 314 24,549 12-14-2020, 02:42 AM
Last Post: jimgl3_imp
  New Key for 2017 CB1100EX michael1954 9 735 04-01-2020, 02:26 AM
Last Post: michael1954
