2017 CB1100EX Brake Bleeding
Need some help regarding bleeding the front brakes on a 2017 CB1100EX. Wanted to change out the old brake fluid. Tried using the typical manual method (open bleed screw, pull brake lever, watch fluid come out bleed screw, close bleed screws, release brake lever, repeat).
The problem I encounter was:
After two or three repetitions, the lever could become stiffer (with the bleed screw open) and finally would not move. No fluid could come out the bleed screw. Seems like something in the ABS module would not let the fluid move to the caliper.
Thanks,
Mitch
I see you’ve seen the other thread on this, so I won’t point you at it. Good luck!
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 891 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,084 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,127 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 638 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 550 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Speedbleeder and bleeding observations satchit 7 578 04-29-2022, 10:46 AM
  Bleeding brakes with ABS j3gq_imp 31 2,203 12-22-2021, 08:31 AM
  Bleeding brakes (CB1100A non-ABS) tod.branko_imp 5 525 09-20-2021, 07:43 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,052 07-19-2021, 08:28 AM
  Shinko 777 tires for my 2017 CB1100ex Chuckk_imp 314 24,662 12-14-2020, 02:42 AM
Last Post: jimgl3_imp
