Lube chain with chainsaw oil
#41
I use an acid brush to apply 90wt gear oil sparingly to the rollers while on the center stand. It doesn't need to get inside the rings, right, that's what O and X ring chains are all about, internally lubed. Don't glop it on and it won't fling off.
thanks[url=https://toolsforpower.com/walmart-chainsaw-sales-reviews-discounted-prices-2022/].
Looks to me as if chains and lube oil isn’t exactly an area where there is a chance that experimenting could do you much good. Compared to the “proper” oil ...
- you could find inadequate oil, but when you “learn” (chain worn) it’s too late,
- you could find cheaper oil, but how much money does that save per mile ?
- you could find bigger containers, but what use if you travel far from home ?
When you consider odds and ends, an oil that sticks a long time, and doesn’t end up in all sorts of places (wheels, hands, exhaust etc) is worth quite a bit of a higher price.
The last quality oil I bought, I put on 700 miles ago - with quite some rain in between. The chain is still well lubed, and no oil seen or found in other places. The can seems to last at least 10x the action, brings down the price per “turn” to under 1$. If it’s that available in Kazach country that’s of course a whole ‘other issue.
Yikes? $1 per "turn"?
Chainsaw oil also cleans as it lubes. Furthermore, my understanding is chainsaw oil (at least the stuff I acquire) is easy on the environment since it tends to spray everywhere in significant quantities. It is not clear to me how well chainsaw oil stands up to UV sunlight exposure and rain water on a motorcycle chain.
  Oinker Chain Lube Tool Gone in 60 4 529 01-15-2025, 08:31 PM
  Preferred chain lube? 2014ltdltz 19 1,536 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 1,047 11-19-2019, 12:57 PM
  Chain Lube Cormanus 68 4,575 07-22-2019, 07:54 AM
  Chain Lube Type and Frequency? Nappi185_imp 29 1,931 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 1,014 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 402 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,241 05-01-2015, 09:03 PM
  Chain lube frequency? Michael252_imp 41 2,758 02-13-2014, 10:52 AM
Last Post: ride4now_imp
