 Oil leak! Help me!
#31
(12-02-2013, 08:07 PM)ingobohn_imp Wrote: Sorry, I am dumb - please help me out: What was the problem?
Oil leakage on the cylinder head cover because of damaged seal and/or glue? Huh (my poor language knowledge)
the owner said leak comes from "cylinder head" he means leak in between the top (white) part of the camshaft cover and the lower one, where there is a 2.5mm rubber gasket in between. the mechanic put come type of sealant on the rubber gasket (he calls glue) to seal off the leak.
he also mentions one of his friend has the same problem, but it go away by itself in his PM to me
So - his leak location is pretty vague, might come from the round cover itself where you can see some silicon glue, or the black rubber gasket
Wonder if re-torqueing valve cover would have taken care of the problem? Strange things have been known to happen.
Thanks for your help!
Thumbs Up
Back in 1979 and thru the 80s when the dohc Honda 4s came out, they had the exact same set up we have now, in that the valve cover was one big piece ( kinda of looked like an H) and there was a large rubber gasket that went in little groove around the whole cylinder head between the head and the cyl head cover. It was imperative that the gasket be clean and that ( going by memory here) that a light layer of silicone be put in the groove on the cylinder head before installing the gasket to hold the gasket in alignment and prevent a leak. The slightest twist or misalignment of the gasket, or a thin spot in the silicone would allow a small leak there under pressure. As these gaskets got older, they stretched from the heat and became increasingly difficult to keep in the groove, and at this point the rubber gasket was usually replaced with a new one.
I'm sorry!
This is a technical problem! Therefore, there are a few specialized terms that I can not translate or description (I had to use pictures to description).
It seems, following is the correct answer!
@cbdtran: Can you translate from Vietnamese into English?
(12-04-2013, 10:26 PM)The ferret_imp Wrote: Back in 1979 and thru the 80s when the dohc Honda 4s came out, they had the exact same set up we have now, in that the valve cover was one big piece ( kinda of looked like an H) and there was a large rubber gasket that went in little groove around the whole cylinder head between the head and the cyl head cover. It was imperative that the gasket be clean and that ( going by memory here) that a light layer of silicone be put in the groove on the cylinder head before installing the gasket to hold the gasket in alignment and prevent a leak. The slightest twist or misalignment of the gasket, or a thin spot in the silicone would allow a small leak there under pressure. As these gaskets got older, they stretched from the heat and became increasingly difficult to keep in the groove, and at this point the rubber gasket was usually replaced with a new one.
For what it's worth, rubber actually shrinks when heated !
Corrects oil leak by: Apply glue (silicone) to detail the number 2 and number 6:
[url=http://www.flickr.com/photos/96952994@N04/11275055226/][Image: bcff8e74b64ab518b3f14788beb5dcd6.jpg]
[url=http://www.flickr.com/photos/96952994@N04/11275055226/]CYLINDER HEAD COVER by [url=http://www.flickr.com/people/96952994@N04/]steed_boy, on Flickr
[url=http://www.flickr.com/photos/96952994@N04/11170181013/][Image: 76123954c71c8406f24e1e74ecf43b1d.jpg]
[url=http://www.flickr.com/photos/96952994@N04/11170181013/]Fix (1) by [url=http://www.flickr.com/people/96952994@N04/]steed_boy, on Flickr
[url=http://www.flickr.com/photos/96952994@N04/11170022556/][Image: 49c5b17738f9ac15b6df2eeb0abaf5df.jpg]
[url=http://www.flickr.com/photos/96952994@N04/11170022556/]Fix (2) by [url=http://www.flickr.com/people/96952994@N04/]steed_boy, on Flickr
[url=http://www.flickr.com/photos/96952994@N04/11170045584/][Image: ed43cf20a6946d2ad28997d617b563d2.jpg]
[url=http://www.flickr.com/photos/96952994@N04/11170045584/]Fix (3) by [url=http://www.flickr.com/people/96952994@N04/]steed_boy, on Flickr
This engine is a beautiful piece of work. Thanks for posting the pictures with the cam cover lifted. It looks nice in there !
Why me???
Looks like I have a similar oil leak on my CB. I took it to the dealer last week to show the leak. The bike has 7100 miles, and the leak has been getting steadily worse over the past 1500 miles. Of course the bike is due for valve inspection/adjustment at 8k. After the holidays, I intend to take the bike in and have the oil leak fixed under warranty. I'm expecting the warranty work will cover the labor to fix the leak, and hopefully reduce the amount of labor charge required for the valve check.
I'm beginning to wonder if the valve cover was removed when they were diagnosing my engine noise ( http://cb1100forum.com/forum/showthread.php?tid=361) and ended up replacing the cam chain tensioner.
My old CX cam covers had rubber gaskets. Finger tight at first and then a touch up when the motor was hot. It always worked.
  Slight Oil Leak DutchRutter 22 3,732 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 197 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,290 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 358 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,179 10-15-2020, 02:13 PM
Last Post: max
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 593 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 396 06-14-2020, 07:17 PM
  Gas leak ? gaby_imp 15 1,009 04-14-2018, 09:29 AM
Last Post: Desert viper_imp
   Oil leak... Please help me.. Coldshot_imp 3 750 06-22-2016, 01:23 AM
Last Post: kmoney_imp
  Oil leak..... mattmcuomo@yahoo.com 19 1,080 05-16-2016, 07:42 AM
Last Post: Riko_imp
