 Oil leak... Please help me..
Hello everyone. I'm James from south korea and I have 2015 cb1100dlx.
By the way, I have found oil leak from the engine side(front, beside of manifold)
I think it looks serious. I only ride my precious cb 3000km,
It looks that oil flowing from the middle of the engine side... Not from the valve top cover side.
Anyone has same problem or any kind of fix it?
My friend told me that this oil leak started from the spark plug side but not sure.
If that is the only place that you see oil, then I wouldn't worry about it. I almost looks as if you ran through something and it landed there.
wash it off with some contact cleaner and see if it returns. No reason for oil to be just there, if it were an oil leak it would run backwards from wind pressure towards the cylinder. almost looks like coke or coffee, rather than oil.
Yup. I wouldn't worry. It's definetely not from a spark plug -- there is no way that oil could leak from the spark plug to the front of the engine. At 3000 miles I'd guess you either ran over something (as mentioned above) or it's just some assembly lube or grease that melted and ran out.
  Slight Oil Leak DutchRutter 22 3,838 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 206 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,335 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 360 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,248 10-15-2020, 02:13 PM
Last Post: max
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 619 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 415 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,727 02-09-2019, 12:22 AM
  Gas leak ? gaby_imp 15 1,048 04-14-2018, 09:29 AM
Last Post: Desert viper_imp
  Oil leak..... mattmcuomo@yahoo.com 19 1,129 05-16-2016, 07:42 AM
Last Post: Riko_imp
