slight oil leak
I have recently had a slight loss of oil on both sides, only behind.
Do I have to open the valve cover or can I do something else?Undecided
Thank you.[Image: 3c192a95e0c12d5f70f12dd136951074.jpg]
[Image: 43d52a4a3cd4af23acdc250f37d0fe8e.jpg]
After doing the valve clearances on one of my other bikes I experienced a very slight weep passed the rubber gasket which settled and stopped by itself after a month. You could take that approach if this is a tiny leak, it won't harm the bike. If it persists then a reseat of the valve cover gasket and some black RTV Silicon Engine sealant around the semi-circular sections is normal (and recommended by Honda) and that should sort it.
Look at that beautiful, tall, silver lump. Thumbs Up
(06-06-2021, 06:12 PM)Enzofour_imp Wrote: I have recently had a slight loss of oil on both sides, only behind.
Why did we only get red and black CB1100's in the States?! I think this bike looks awesome in white, blue or yellow too!
  Slight Oil Leak DutchRutter 22 3,963 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 215 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,397 06-17-2021, 10:18 AM
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,396 10-15-2020, 02:13 PM
Last Post: max
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 658 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 439 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,861 02-09-2019, 12:22 AM
  Gas leak ? gaby_imp 15 1,135 04-14-2018, 09:29 AM
Last Post: Desert viper_imp
   Oil leak... Please help me.. Coldshot_imp 3 791 06-22-2016, 01:23 AM
Last Post: kmoney_imp
  Oil leak..... mattmcuomo@yahoo.com 19 1,193 05-16-2016, 07:42 AM
Last Post: Riko_imp
