04-25-2016, 04:24 AM
Looks like this black plug is leaking some oil... anyone have this happen to them?
Sent from me......
Sent from me......
Oil leak.....
Sent from me......
04-25-2016, 06:44 AM
Looks like it's weeping a bit. That looks like it's just an oil galley plug, and doesn't hold anything in (I'm sure someone with a manual can confirm that). At you're next oil change, maybe just pop it out and try putting some aviation sealer or thread sealer on the threads and just reinstalling. I wouldn't be too worried about it though, as it's not much of a serious leak.
04-25-2016, 06:49 AM
Not worried really, still under warranty, going to take to dealer... make them take care of it!
Sent from me...... Just hoping it's not some kind of on going issue. The bike only has 7000 miles on it! Sent from me......
04-25-2016, 07:23 AM
(04-25-2016, 06:49 AM)MMC_imp Wrote: Not worried really, still under warranty, going to take to dealer... make them take care of it!Just leave it alone. Wipe it off, maybe. You take it out, it might start leaking even more if you don't follow Honda's exact procedure (no kidding). 7000 miles and just a very thin film oozed out, it's nothing to worry about at all. When you get done worrying about that, you can worry some about how many other riders failed to wave at you.
04-25-2016, 07:37 AM
leaks drip. I don't see any drips
ride more...worry less
04-25-2016, 07:59 AM
04-25-2016, 09:07 AM
That's not oil from that plug as far as I can tell. Whatever it is, it's coming from in front of the plug.
04-25-2016, 09:36 AM
(04-25-2016, 07:59 AM)MMC_imp Wrote:That's what I was thinking until I saw this...(04-25-2016, 07:37 AM)The ferret_imp Wrote: leaks drip. I don't see any dripsThat's what I was thinking until I saw this... Sent from me...... Oh yea, I don't like the looks of that, but it looks like rust water running to me. With that much oil gone you'd think there would be a drop of oil hanging from the cap. I'd spray it with some contact cleaner, clean it real well, then take it for a spin and see if there is any oil leaking from there.
04-25-2016, 09:47 AM
It does look like a gallery plug, both on the bike, and in the crankcase section of the service manual. I couldn't find it mentioned specifically. I also could not tell where it is shown, if it is, in the parts fiche.
Mine is not weeping. I would suggest what Randy says and look forward. Check the oil filter and the oil cooler tube that mounts down low for leaks. Notice that there is no oil on the frame tube below the plug. I don't think it is dripping or there would be oil on the frame tube, I would think.
04-25-2016, 10:05 AM
Oil looked low because it was not warm enough. Cleaned it up, rode it home, looks fine. Oil level is good. Not worried anymore... thanks for responses. I'll keep an eye on it still.
Sent from me...... |
« Next Oldest | Next Newest »
| Slight Oil Leak | DutchRutter | 22 | 3,832 |
05-16-2025, 06:49 AM Last Post: peterbaron |
| Oil Leak? | bvictory_imp | 0 | 206 |
06-14-2023, 07:05 AM Last Post: bvictory_imp |
| Just found a leak | Gone in 60 | 20 | 1,335 |
06-17-2021, 10:18 AM Last Post: Lord Popgun |
| slight oil leak | Enzofour_imp | 3 | 360 |
06-07-2021, 12:26 AM Last Post: michael1954 |
| Oil Leak - Just got work done and then moved. | NickyV_imp | 34 | 2,243 |
10-15-2020, 02:13 PM Last Post: max |
| Cylinder Head cover oil leak and valve clearance increase. | zirconxi_imp | 6 | 612 |
09-01-2020, 12:19 AM Last Post: peterbaron |
| Oil leak from pulser cover? | skatamutra_imp | 4 | 414 |
06-14-2020, 07:17 PM Last Post: Lord Popgun |
| Oil leak! Help me! | steed_boy_imp | 43 | 3,710 |
02-09-2019, 12:22 AM Last Post: GoldOxide_imp |
| Gas leak ? | gaby_imp | 15 | 1,048 |
04-14-2018, 09:29 AM Last Post: Desert viper_imp |
| Oil leak... Please help me.. | Coldshot_imp | 3 | 762 |
06-22-2016, 01:23 AM Last Post: kmoney_imp |
