Chain Lube
#31
(07-01-2019, 03:39 AM)Rocky_imp Wrote:
(07-01-2019, 03:05 AM)SportsterDoc_imp Wrote: For the CB I used Dupont Chainsaver ($7 at Walmart)
It is labeled"o-ring safe"
I stocked up on the Dupont Teflon multi-purpose dry wax spray lube just before it was discontinued in favor of the Chainsaver.
I have two cans untouched and one in use so I'm going to continue with my usual routine regardless, as somebody said, even though I know now I may be wrong Big Grin Big Grin Big Grin
Think I used the multi-purpose on other bikes.
Also o-ring safe
I have been rolling over my ol' cans of Dupont Chainsaver to my hedge trimmers. Undecided
Great video. The owner's manuals from my ex-1970 CB750K0 and ex-1978 CB750F2 both recommend using 80/90 gear oil. I guess some things never change.
(07-01-2019, 05:30 AM)LongRanger_imp Wrote: Great video. The owner's manuals from my ex-1970 CB750K0 and ex-1978 CB750F2 both recommend using 80/90 gear oil. I guess some things never change.
Yep, I did not like cleanig oil off the rim of my '76.
One advantage of modern wax based spray is no fling.
Not an issue on the V7II or either Sportster!
Shaft. Now you're talkin' (V7).
And a great shaft drive!
If only the fueling worked as good as my EFI Triumph, Yamaha and Honda.
I lamented the passing of the old formula DuPont lube. Cheap and plentiful at Walmart.
Might switch to Tirox when my Maxima supply is exhausted, but took me quite a while to get the Grease Monkey to work just right with their can...
Had to scroll back up to see your post, Nortoon. Nobody here sells it on the shelf that I’ve found.
(07-02-2019, 01:56 AM)Gone in 60_imp Wrote: I lamented the passing of the old formula DuPont lube. Cheap and plentiful at Walmart.
I Googled and a number of Canadian Stores popped up. Grabbed the tin and found it is made in Canada. Found this on the Tirox website.
Thanks, Nortoon. Found it online in plenty of places. I'd like to find a can on a local shelf, but I can order it easily enough. Have two Cycle Gear stores near me, but it's a special order item for them. Would kind of like to see what the nozzle looks like and if I can easily adapt my semi-custom Grease Monkey setup to their can, not that it would be a deal breaker.
There are a number of ways of limiting the mess from spray cans.
I found a plastic tube from another spray can that fit in the Tirox nozzle.
Lemmy's method of laying the tube straight down the chain rollers works well.
The chain links keep the tube in place.
I use a piece of cardboard behind the chain to catch the excess when spraying the outside links.
Have not found a clean way for the insides links yet.
Fortunately the clear wax seems to last longer than messy black greases and lubes.
  Oinker Chain Lube Tool Gone in 60 4 539 01-15-2025, 08:31 PM
  Lube chain with chainsaw oil mrded_imp 43 3,427 06-01-2022, 01:20 AM
  Preferred chain lube? 2014ltdltz 19 1,607 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 1,134 11-19-2019, 12:57 PM
  Chain Lube Type and Frequency? Nappi185_imp 29 2,164 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 1,041 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 415 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,301 05-01-2015, 09:03 PM
  Chain lube frequency? Michael252_imp 41 3,008 02-13-2014, 10:52 AM
Last Post: ride4now_imp
