Threads: 45
(12-02-2020, 04:25 AM)suryamp_imp Wrote: (12-01-2020, 08:56 PM)peterbaron_imp Wrote: (12-01-2020, 02:54 PM)suryamp_imp Wrote: Sorry to resurrect an old thread, but what are the part numbers for that green connector and black rubber surround? Have to tackle the OEM heated grip installation myself.
This is for 2017, check your model prior ordering:
https://www.hondapartshouse.com/oemparts...-fuel-pump
Yeah I have a 2017 too and in the 2013 and 2014 part diagrams it is easy to find the green connector and rubber piece but in the 2017 diagrams I can't seem to find it. I'm wondering if the 2017s don't have the part...
For 2017 and later years, The connector is of a completely different construction, there is no green connector anymore- It's been replaced by the "milky white" colour lock which should be replaced everytime it's been disconnected (as per Honda manual). I placed a picture of the newer version connector and instructions there in the "How to" section.
[url=http://cb1100forum.com/forum/showthread.php?tid=14975&page=2]http://cb1100forum.com/forum/showthread....975&page=2
Regards
Alain
Threads: 63
Likes Given: 8
When I disconnected my fuel line the connection would NOT come apart using my fingers. No matter how hard I squeezed the green plastic tangs together they would not disengage from the mating part. Snapping the two halves of the joint together forces the female side of the joint to expand, allowing the tapered surfaces of the green (male) side of the joint to slide into position. Maybe it was just the manufacturing tolerances, but the green (male) piece would not disengage using finger pressure. I was forced to use a needle nose plyer and a small screw driver to get the joint apart, and ended up damaging the plastic pieces and having to replace the entire connection. In my opinion, this is a terrible design.
I watched this video. I can't believe the fuel line connection can be disconnected that easily and quickly - can I please get comments from other people who have removed their fuel tanks?
Threads: 2
(12-02-2020, 05:33 AM)Alain Lee_imp Wrote: (12-02-2020, 04:25 AM)suryamp_imp Wrote: (12-01-2020, 08:56 PM)peterbaron_imp Wrote: (12-01-2020, 02:54 PM)suryamp_imp Wrote: Sorry to resurrect an old thread, but what are the part numbers for that green connector and black rubber surround? Have to tackle the OEM heated grip installation myself.
Regards
Alain
[url=https://www.hondapartshouse.com/oemparts/a/hon/5907901f87a8660d54fac32c/fuel-tank-fuel-pump]https://www.hondapartshouse.com/oemparts/a/hon/5907901f87a8660d54fac32c/fuel-tank-fuel-pump
Regards
Alain
By chance do you have the part #? I looked in the links you posted and it doesn't seem to contain one. I see 17526-MGC-JB1 but I think that just replaces the entire hose and I'm not sure the connector is even included.
Threads: 45
Yes, you have to replace the entire hose (the white piece is not sold separately)
Chuckk of "Ventura" California did replaced the hose, may be he can confirm the part number.
Regards
Alain
