 Resistance of Fuel Tank 2014CB1100
Hi All,
Can anyone tell me the resistance of full tank and empty tank of 2014 CB1100?
Since I just change new meter to ACEWELL MD085-553,and the meter show only 1 bar ( I've tried all the options in the meter)
Thank you.
Image deleted for copyright reasons.
i believe this is the us version 2014
i_x, this may help you:
http://cb1100forum.com/forum/showthread....LL++speedo
Looking at the instructions for the meter on the Acewell site, it appears that the closest setting is Full 10 Empty 250. But the instructions seem to indicate you can program in your own setting. Not really clear though. Might have to call them if the values shown by CJ don’t help you.
Just in case the above post gets moderated, the values are Full 5-7ohms, Empty 204-210ohms
Thank you all for the answers.
I am trying to “set up” new meter : gears, speed, odometer, temperature and fuel bars
[Image: 4aa3a31e28e674461293f1778e134e3c.png][Image: 9dcf37a99d49a3e869b00a453bf880cf.png]
I had to remove the original meter after an accident.
... and while at itsok_xman, welcome to this fine Forum!
(03-31-2021, 12:12 PM)itsok_xman_imp Wrote: Thank you all for the answers.
I'm here to tell you- IT"S OKAY, MAN!
Someone will be here shortly to provide wiring pinouts
Are you running the stock forks with the turn signal/cluster gauge bracket?
Would love to see how the whole thing turns out once it's all said and done Thumbs Up
[Image: 2817cead3516a192428bf954e7b95700.jpg]
I installed this one.
Since I haven’t done the set up, so when I ride, it does not show the right number [Image: 6133cf27c0fc057ee442b70dc3a560ef.png][Image: a2d444e8b5872e933932bc5b4ce31323.png]
I am riding ~50mph, it shows 0.1mph lol
And also, it shows the temperature reaches 200F. So sad
  CB1100RS fuel tank rust Narciso 12 1,332 09-27-2025, 02:06 PM
Last Post: tdbru
  CB1100 fuel tank upgrade johnnyH_imp 3 444 03-13-2024, 01:31 AM
  Front brake inconsistent resistance ChiefJP_imp 16 1,362 06-14-2023, 07:46 AM
Last Post: bvictory_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,552 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 682 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
  How to empty the fuel tank? Ulljanrich_imp 23 1,745 07-20-2020, 04:45 AM
Last Post: TXBikerGuy
  Fuel Tank Removal Gabby_imp 11 901 06-19-2020, 10:54 AM
  Fuel Tank overflow drain tube. zirconxi_imp 11 866 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  What's living in your fuel tank? max 4 349 11-05-2019, 08:42 AM
  OEM Fuel Tank Replacement Questions suhawk305 18 1,086 09-02-2018, 02:28 AM
Last Post: suhawk305
