USB ON HANDLEBAR - connection at battery direct .
Alfgaxatico_imp Offline
Threads: 17
RE: USB ON HANDLEBAR - connection at battery direct .
Where can buy it ?? The brake fluid cover ??? eBay ? AliExpress ? Please
12-28-2020, 07:40 AM
Mtneers Offline
Threads: 9
Likes Given: 22
(12-28-2020, 07:40 AM)Alfgaxatico_imp Wrote: Where can buy it ?? The brake fluid cover ??? eBay ? AliExpress ? Please
Yes...Aliexpress....
12-28-2020, 08:26 AM
Threads: 17
Ufff difficult send ..
I,ll look it now ..
Enviado desde mi iPhone utilizando Tapatalk
12-28-2020, 08:48 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Amazon shows some CB1100 covers too.
12-28-2020, 08:58 AM
17-CB-002 Offline
Threads: 45
Here is another style of reservoir brake cap from AliExpress
Caution, it comes in pair, meaning that I have an extra 2 covers in my drawer.
Thanks to mtneers for his info Wink)
Regards
Alain
12-28-2020, 01:24 PM
bflint Offline
San Diego
Threads: 72
Likes Received: 24 in 7 posts
Likes Given: 7
#26
Using a "Switched Power Source" just insures you don't accidently drain your battery.
Here is pic of my 2014 CB1100 DX (USA EX model) headlight cone showing my "auxiliary power" connections that I hooked into the unused RED switched power connector. This RED switched power connector is used for the heated grips if you have them installed.
1. The RED switched power connector is at the top of the pick.
2. I bought the white plastic female connector to snap on to it, but you don't need this.
3. The brown and red wires coming out of the white plastic female connector go to my USB power on my handlebars.
4. I piggy backed my spot lights onto the RED switched power connector via the blue tap connector with the white wire coming out of it.
12-29-2020, 08:23 AM
Threads: 17
#27
Thanks ..
But I have a heated grips ... installed
Then ... is not possible connect the usb charger too ???
I,ll must connect to under seat aux option ???
01-01-2021, 08:00 AM
Lord Popgun Offline
Virginia
Likes Given: 142
#28
Sure you can Alfgaxatico, you can connect more than one device to the accessory connector. Just remember it is fused 10amps so don’t overload the circuit.
01-01-2021, 09:36 AM
Threads: 17
#29
Okay ; installation finished with USB charger Quad Lock .. I have gone to the official Honda of my city; and they have installed an auxiliary connection (my model is cb1100 ex 2015 Europe); which is under the seat next to the battery (cable option 2 service manual). the cost of it; in addition to changing the DOT 4 hydraulic clutch fluid; It was € 43 ... I think it was worth it for them to do it.
01-19-2021, 02:47 AM
j3gq_imp Offline
Threads: 78
#30
Glad you installed the USB port and it works, and there is little reason to complain about this price. But for other readers let me propose a different solution, one without installation at all. Buy an "Olight" RN 800 (or similar) from ebay. When you mount this little thing to your handle bar (in under 2 minutes) it provides for
- an autonomous USB charger (large LiIon battery),
- a very powerful (spare) head light,
- a flasher to use in daylight (similar to what a Kisan modulator does, different modes).
And all this without splicing the motorcycle's harness, without any risk that connections made may later corrode.
And for those of us riding in Europe it comes with another advantage over the Kisan modulator, it is entirely legal.
The good's enemy is the better Wink
01-20-2021, 04:37 AM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 323 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,688 08-07-2025, 05:24 AM
  Handlebar Risers?? bubblerboy64_imp 16 1,457 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  Usb-c cable direct to battery or switched power capz65_imp 5 558 04-16-2022, 02:26 PM
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 750 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 541 04-03-2022, 01:00 AM
  my deluxe is broken... missing battery box cover!! Sparky80_imp 6 606 10-13-2021, 02:09 AM
  Handlebar from 919 motorider6_imp 10 911 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 234 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,423 12-16-2020, 10:40 PM
