What to do with the handlebar mounts when converting to clip-on controls?
misterprofessionality Offline
Threads: 126
Likes Given: 1
As the title says, I'm trying to come up with some valid ideas on what to do with the mounting positions of the old handlebar clamps in the triple in the event that I should hypothetically change my controls to clip ons.
Woodcraft makes a really nice set of adjustable side mount clip ons with 3" risers and extra long bars, which i'm considering as a part of a series of modifications to make my CB just a bit more aggressive on the ergos to cope with my riding style. However, I'm at a loss as to what to do with the holes left in the triple by the original handlebar clamps. Is there something useful I can do with this? I'm sure I could just jam a bolt in there or something to fill it but I feel like it's an opportunity to put something cooler in.
If anybody has converted a handlebar to clip ons on any motorcycle in the past and you had a way of dealing with these cavities, Please let me know. I need ideas.
04-07-2022, 11:57 PM
Sparky80_imp Offline
Threads: 3
RE: What to do with the handlebar mounts when converting to clip-on controls?
Haven't done anything like that but I'm sure you could put a RAM mount for at least 1 of those holes.
Or, you could get a custom made upper triple and bypass those holes alltogether. Never used these guys before but they seem to have great workmanship in their products... https://cognitomoto.com/products/custom-...2956138611
04-08-2022, 12:18 AM
Threads: 126
Likes Given: 1
cognito would certainly have the cleanest option but also the most expensive. woof. AGRAS also makes a full clip on- billet top clamp for a lot less than that and it includes the clip ons and risers. I'd rather go JDM in that case.
either way replacing the top clamp is a massive expense i don't think I need to get into. I'd sooner just get flatter, lower handlebars and forego the clip ons altogether.
04-08-2022, 12:44 AM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Received: 179 in 104 posts
Likes Given: 480
Way above my pay-grade. Really interested in what you come up with.
04-08-2022, 01:33 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,196 in 513 posts
Likes Given: 972
Why not find two decorative caps that will fill the holes, paint them the same color as the top clamp, and attach?
04-08-2022, 01:37 AM
Threads: 126
Likes Given: 1
I suppose because I'm not sure if such caps are already purpose built or what size they would be or anything. I did some searching already and came up empty. I figured that meant I was missing some terminology that others might have run across in their experience. improvisationally, I'd probably just go searching stainless steel button cap screws until I found the right length and diameter, put a rubber washer and a steel washer under both sides and just tighten it down. However, it also occurred to me that maybe there's some useful or creative alternative i'm not thinking of.
04-08-2022, 01:40 AM
Pauley Offline
Walnut Creek, CA
Threads: 14
Likes Received: 14 in 9 posts
Likes Given: 20
I found this option: https://jokermachine.com/products/handle...plug-black for $29 might be others out there.
Have you tried looking at a well stocked hardware store for a plug or cap that might work? That would likely be a just a few dollars at most.
04-08-2022, 02:43 AM
Threads: 126
Likes Given: 1
Thats the ticket! I guess i just didnt know what to call it. I knew there must be a specific priduct for this purpose.
04-08-2022, 03:41 AM
  [SOLVED] Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack? JRD 14 981 07-09-2026, 07:38 PM
Last Post: JRD
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,697 05-17-2026, 10:20 PM
  Tires ~ Converting tube to tubeless type. 17-CB-002 30 2,244 05-14-2026, 05:50 AM
Last Post: Kikemon
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 316 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,651 08-07-2025, 05:24 AM
  Flipping the handle bar mounts around 1985CB450_imp 4 472 10-11-2022, 05:21 PM
Last Post: Mixagon_imp
  finished "forward controls" today Griz53_imp 12 996 10-02-2022, 10:44 PM
  Handlebar Risers?? bubblerboy64_imp 16 1,449 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 534 04-03-2022, 01:00 AM
  Handlebar from 919 motorider6_imp 10 897 05-27-2021, 12:47 PM
Last Post: Stichill
