- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
Usb-c cable direct to battery or switched power
| Author |
Message |
capz65_imp
Threads: 5
Looked all over and can't seem to find a fused usb-c cable with battery leads or a ready made usb-c cable to a 2 pin connector. I'd like the usb-c male right at my phone mount instead of plugging in a USB to usb-c cable. Anyone have this setup?
| 04-15-2022, 10:34 PM |
Lord Popgun
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Usb-c cable direct to battery or switched power
My guess is you are going to have to use an adapter. If you search on motorcycle USB C on Amazon a ton of options come up.
On my bike I have an SAE cable plugged into the accessory connector in the headlight. The other end I can plug in any number of adapters or devices. Right now I have a voltage monitor on it.
| 04-15-2022, 11:16 PM |
capz65_imp
Threads: 5
Right, I have the micro USB with adapter running to fused sae then to battery. It's worn with cracked sheathing so I wanted to replace it. Surprised they haven't gone to the straight usb-c yet. So there's a wired available SAE in the headlight? That's a score. Wish I knew that before I wired the ring terminals to the battery. The terminal screws were 1 damn mm too short to catch the nut underneath with the added width of the terminals. Took a half hour to lift the nut high enough to catch. Thanks for the better suggestion.
| 04-16-2022, 11:25 AM |
Lord Popgun
Virginia
Likes Given: 142
The accessory connector in the headlight shell is not SAE. It is a 2 pin red connector. Sumitomo or Hitachi, I forgot which at this moment.
To use it you have to buy a connector and pins and attach them to a an SAE cable or just cut off the bike connector and attach directly to the wires. That is what most have done. Some of us bought the connector that fits the bike.
| 04-16-2022, 11:30 AM |
capz65_imp
Threads: 5
Ok I got it. Same as the one in the boot under the toolbox. I'm on it
| 04-16-2022, 12:21 PM |
Lord Popgun
Virginia
Likes Given: 142
(04-16-2022, 12:21 PM)capz65_imp Wrote: Ok I got it. Same as the one in the boot under the toolbox. I'm on it
| 04-16-2022, 02:26 PM |
| Possibly Related Threads… |
| Thread |
Author |
Replies |
Views |
Last Post |
USB ON HANDLEBAR - connection at battery direct . |
Alfgaxatico_imp |
38 |
2,598 |
05-17-2026, 10:20 PM
Can someone with a power commander on a 6-speed bike check something for me? |
PowerDubs_imp |
10 |
860 |
05-15-2022, 11:42 AM
Power Distribution Module (PDM) - Europe/UK |
Tev62 |
5 |
539 |
11-16-2021, 07:49 PM
Last Post: j3gq_imp
my deluxe is broken... missing battery box cover!! |
Sparky80_imp |
6 |
591 |
10-13-2021, 02:09 AM
Power Commander 5 and Dyno Tune |
iamheero_imp |
7 |
571 |
07-18-2020, 04:14 AM
Power Port for 2014 CB1100A (Deluxe) |
MWV1500_imp |
5 |
459 |
12-06-2019, 09:00 AM
Power commander. |
kmoney_imp |
19 |
1,528 |
08-19-2019, 09:38 AM
Last Post: Ben70_imp
2013 cb1100 power commander help |
2000zx750r_imp |
4 |
457 |
06-16-2019, 05:43 PM
Auxillary USB Power Plug install for IPhone |
Frulk_imp |
22 |
1,227 |
05-12-2019, 06:00 PM
Last Post: Bazbro_imp
JB-Power Magtan JB4 Magnesium wheels |
lola_imp |
37 |
2,067 |
07-03-2018, 10:05 PM
Last Post: FLYTYM_imp
