HANDLEBAR RISERS - is really necessary???
Alfgaxatico_imp Offline
Threads: 17
handlebar risers. I just saw that my CB1100 ex 2015 Europe; It has 2.5 cm of handlebar risers. I measure 1.85 and known that it makes the weight more centered; It is advisable ? I know that the easiest thing is to remove and test; But this original series bike has always been said to be very comfortable and I don't like to vary the steering elements on my bikes. I had not noticed .
Enviado desde mi iPhone utilizando Tapatalk
12-12-2020, 08:19 PM
tod.branko_imp Offline
Threads: 19
I think it's personal preference, I lowered the bars for about an inch and moved them quite a bit forward, in return I got slower steering which helps with high-speed stability. The low speed steering response is obviously affected in the same way, so requires more input. I find this setup more comfortable, too. Note these are subjective findings
'14 CB1100 STD 5 speed
12-12-2020, 08:47 PM
Threads: 17
RE: HANDLEBAR RISERS - es realmente necesario???
I in all comparisons; the EX version with 18-inch wheels; it gave better maneuverability; having wide handlebars. the subject that on the road; I will travel with a companion; and suitcase; I don't like the front axle weight being transferred a bit further back (handlebar rise effect). Magín or that I should remove and test them; but he doesn't like to change the address for convenience; since I understand that the rider must adapt to the Moto in this aspect.
12-12-2020, 09:13 PM
Threads: 19
Risers don't make the handlebars wider, you need wider handlebars for that, consider that. I put 80cm wide dirt bars in my '14 STD, and it also has 18' wheels, wouldn't have it any other way. And this is from a person who spends 80% of the time going 130-140 on the highway. Just remove the risers and enjoy the ride
12-12-2020, 09:38 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: HANDLEBAR RISERS - is really necessary???
The CB is fine for me stock. I do have them on the ST though.
12-12-2020, 10:26 PM
Threads: 17
Thanks . sorry ; I explainned wrong . the EX 2015 Europe model; It already has a wide and comfortable handlebar as standard. I meant that I don't like the weight - I'm already a big man and my companion (64 kg) - is removed from the front. in February I got the ohlins stx36 suspensions to change the rear suspension. that's why I'm going to leave the handlebars without the risers; and I'll get used to the original position. I come from an Africa Twin Adventure Sports 2018; and it's not a problem
12-12-2020, 10:30 PM
Inhouse Bob Offline
Threads: 34
Likes Given: 15
Unless you are racing or riding at the bike's limits, a bit of bar adjustment one way or the other won't matter much. It really comes down to what you find most comfortable. For a lot of us old guys, the stock bar height is too low for long-ride comfort. But others like clip-ons and the cafe racer look and feel. I'm kind of short-armed, so I have the bars both raise and pulled back. Find what feels good to you and enjoy the ride Thumbs Up
12-13-2020, 12:00 AM
Threads: 17
Mmmmm . I,m 56 years old ... I not be a younger .. hahahahahaha
But .. the height... at front .
12-13-2020, 01:02 AM
I considered risers for the same reasons as Inhouse Bob described. I ultimately decided to keep the handle bar position stock. Like many things, definitely a subjective measure.
12-13-2020, 01:18 AM
Houtman_imp Offline
Threads: 115
Stock handle bars are perfect for me at 1.80
12-13-2020, 02:20 AM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,598 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 313 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,606 08-07-2025, 05:24 AM
  VOIGT Risers Duderino_imp 3 440 11-23-2024, 01:09 AM
Last Post: Obleo
  Handlebar Risers?? bubblerboy64_imp 16 1,445 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 716 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 527 04-03-2022, 01:00 AM
  ROX Risers and longer brake line? MrBob_imp 3 430 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Rizoma risers on the cb1100 Zee9_imp 20 1,489 05-28-2021, 02:20 PM
Last Post: Zee9_imp
  Handlebar from 919 motorider6_imp 10 876 05-27-2021, 12:47 PM
Last Post: Stichill
