USB ON HANDLEBAR - connection at battery direct .
Alfgaxatico_imp Offline
Threads: 17
Mount an USB on handlebar. I want to place a USB on the handlebar; and asked ; if I have to lift the fuel tank from the screw next to the battery; a little or should I let go of the gas hose; and the connector. that's a question. the other: the battery to connect the cables; if I disconnect it; Everything returns to normal after reconnecting it or an alarm will go off and I will have to go to a Honda mechanic workshop?
Enviado desde mi iPhone utilizando Tapatalk
12-26-2020, 02:04 AM
White Dog_imp Offline
Threads: 59
RE: USB ON HANDLEBAR - connection at battery direct .
(12-26-2020, 02:04 AM)Alfgaxatico_imp Wrote: Mount an USB on handlebar. I want to place a USB on the handlebar; and asked ; if I have to lift the fuel tank from the screw next to the battery; a little or should I let go of the gas hose; and the connector. that's a question. the other: the battery to connect the cables; if I disconnect it; Everything returns to normal after reconnecting it or an alarm will go off and I will have to go to a Honda mechanic workshop?
You can run your wiring along the underside of the gas tank and attach to your battery terminals. No need to lift the tank. Note that power will always be "on" to the USB unless you have a power on/off switch on your USB.
12-26-2020, 08:02 AM
Threads: 17
Thanks ; is the Quad lock usb system ; it have a fuse and system “cut” if not have a charge ... I think that the items intelligent (at same Apple) ; not have a current ...
Seamlessly integrate the Motorcycle USB Charger with any Quad Lock Moto Mount (Handlebar, Mirror or Fork Stem) or 1" Ball Adaptor.
The Charger is neatly positioned under the Quad Lock mount head to provide USB power without the need for long charging cables.
The 1.5m SAE connection cable and 20cm SAE to battery ring terminals give you the option to connect directly to your Battery Terminal or existing SAE Port. The charger draws Zero current when not in use so there is no danger of draining your battery.
FAST CHARGING & SURGE PROTECTION
The Quad Lock Motorcycle USB Charger supports Quick Charge 2.0 for Fast Charging. With integrated Surge and Polarity Protection to keep your device safe from human error (also known as wrong installation).
This item is current zero . It have a Diode at integrated circuit for these ..
https://www.quadlockcase.eu/collections/...8888462418
12-26-2020, 08:05 AM
17-CB-002 Offline
Threads: 45
Why not use the "switched" power outlet from inside the headlight bucket?
If you want to make a professional connection to the 2-pin plug, the male connector is available - see other treads to find the part number and supplier.
http://cb1100forum.com/forum/showthread.php?tid=16367
http://cb1100forum.com/forum/showthread....=connector
12-26-2020, 08:20 AM
Threads: 17
Mmmm ... it,s an idea ... but if the item ; is zero current if don,t detect charge (iPhone) ... is good ; but you have a reason.
But .. the Consum will be an 2 Amperes ... into the front. Light ; I don,t know wich current can work .. one light ; 55 W ; and 12 v tension .... (P=V*I) ; then 55W/12 v = 4,5 A ....
could be ... mmmmm
12-26-2020, 08:23 AM
17-CB-002 Offline
Threads: 45
(12-26-2020, 08:23 AM)Alfgaxatico_imp Wrote: Mmmm ... it,s an idea ... but if the item ; is zero current if don,t detect charge (iPhone) ... is good ; but you have a reason.
could be ... mmmmm
No, this is separate from the headlight bulbs, It is an auxiliary power supply for hooking up 12v accessories (up to 10 amps).
Regards
Alain
12-26-2020, 08:32 AM
Threads: 17
Thanks Alain ; but I don,t know where are the connection .. my bike are 2014 model ; CB 1100 ex ;
Can you give me a idea where are ??
Thanks my friend
12-26-2020, 08:34 AM
Also note: If you happen to have a 12V-to-USB adapter connected and the circuit remains unswitched, the adapter will draw a small amount of open-circuit current from the battery. This is less than ideal.
12-26-2020, 08:38 AM
Cormanus Online
Likes Given: 1,010
Alf, the 2014 has the free switched connector in the headlight. Someone else can chime in, but I seem to recall it's red and, if the bike is stock, there's nothing connected to it.
12-26-2020, 08:43 AM
17-CB-002 Offline
Threads: 45
(12-26-2020, 08:34 AM)Alfgaxatico_imp Wrote: Thanks Alain ; but I don,t know where are the connection .. my bike are 2014 model ; CB 1100 ex ;
Thanks my friend
The same connector is for 2013 up to 2017 (and later model?)
Please see the 2 links in mentioned (mine) tread above.
the fuse is good for 10 amps which is more than required. plus it is a switched power.
It explain everything you need to know and also where to buy the connector on line. http://www.cycleterminal.com/hm-sealed-series-090.html
12-26-2020, 08:45 AM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 313 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,615 08-07-2025, 05:24 AM
  Handlebar Risers?? bubblerboy64_imp 16 1,445 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  Usb-c cable direct to battery or switched power capz65_imp 5 545 04-16-2022, 02:26 PM
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 717 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 527 04-03-2022, 01:00 AM
  my deluxe is broken... missing battery box cover!! Sparky80_imp 6 592 10-13-2021, 02:09 AM
  Handlebar from 919 motorider6_imp 10 877 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 230 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,347 12-16-2020, 10:40 PM
