Chain lube frequency?
My Bel Ray can says BLUE TAC CHAIN LUBE, O-X-Z RING SAFE.
Its the ultimate chain lube--must be, says so right on the can! Smile
I really like whatever came on my chain from the dealer...but my question is - do our chains come from Honda already lubed, or does each specific dealer apply the initial application? I'd like to buy exactly what is on it now. Seemingly good stuff...has a slightly white color to it, but it hasn't flung much, and doesn't attract dirt from what I can tell.
They come prelubed probably not from Honda, but from the chain manufacturer.
There are several brands of spray chain cleaners that are proven safe for O-ring chains. Park your bike over a dirt surface up on it's center stand and spray the chain clean while you spin the rear wheel. While it's wet with the chain cleaner spin the chain through a chain cleaning brush (about $7 from Cycle Gear). After brushing it wet I spray it down once more with the cleaner to wash away whatever the brush worked loose. Let it dry for about 15 minutes and then spray it with an O-ring chain lube. Again, let it sit for 15 minutes and then ride. After my first ride I use degreaser on a rag to wipe off whatever flung off onto the rear wheel and then you're good to go. 500 mile intervals are good because it's easy to keep track of. All the best.
Chip
did anyone get that new honda chain lube with the white graphite in it.? i guess mine came with it on the chains when she rolled out from the dealer.. white in color..
(08-01-2013, 06:26 AM)wildezt_imp Wrote: did anyone get that new honda chain lube with the white graphite in it.? i guess mine came with it on the chains when she rolled out from the dealer.. white in color..
I think that's just bog-standard lithium grease.
I clean my chain with Simple Green, liberally applied, and a rag. Spray the entire chain, then slowly go through each section of the chain, re-spraying and cleaning with the rag until complete. Let dry (about 20-30 minutes, probably takes less time, especially in the desert here, but I believe in the 2x rule for time). Then I liberally apply Honda chain lube, wipe the excess, and I'm done. The thing I like about the Honda chain lube is it never flings any anywhere. I've got about 18k miles on my CBR's chain with this process and it's still got a ways to go before it's stretched to the point of replacement. The chain itself looks brand new.
I use DU PONT Teflon Chain Saver buy it by the case at Lowes. I lube every 300mi & you can go much longer between cleaning. The chain never gets dirty. I use kerosene to clean with a chain brush usually every oil change. I have 32,000mi on my XX Blackbird & still has the original chain.
I use Chain Cleaner Degreser by Motorex, wipe it off with a rag and use PJ1 BLUE LABEL chain lube. The Can says "Won't Fly Off" but this is not true. The stuff flies everywhere, back wheel gets full of gunk. I even find some on the seat and tail light. Not sure if this is normal. I'll try using some of the other products mentioned here. Maintenance was so much easier on the shaft drive Magna.
(07-27-2013, 03:06 AM)ChipBeck_imp Wrote: There are several brands of spray chain cleaners that are proven safe for O-ring chains. Park your bike over a dirt surface up on it's center stand and spray the chain clean while you spin the rear wheel. While it's wet with the chain cleaner spin the chain through a chain cleaning brush (about $7 from Cycle Gear). After brushing it wet I spray it down once more with the cleaner to wash away whatever the brush worked loose. Let it dry for about 15 minutes and then spray it with an O-ring chain lube. Again, let it sit for 15 minutes and then ride. After my first ride I use degreaser on a rag to wipe off whatever flung off onto the rear wheel and then you're good to go. 500 mile intervals are good because it's easy to keep track of. All the best.
Chip
G'day Chip,
That is my routine also. In addition I clean and lube after significant rain and/or dirt and gravel. Have found MOTUL brand to be very effective, if a tad expensive. MOTUL is also well reviewed in comparison tests by the appropriate "Gurus".
  Oinker Chain Lube Tool Gone in 60 4 472 01-15-2025, 08:31 PM
  Frequency of chain oiling? Rebel73_imp 48 3,450 09-28-2023, 05:55 AM
  Lube chain with chainsaw oil mrded_imp 43 2,861 06-01-2022, 01:20 AM
  Preferred chain lube? 2014ltdltz 19 1,346 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 988 11-19-2019, 12:57 PM
  Chain Lube Cormanus 68 4,259 07-22-2019, 07:54 AM
  Chain Lube Type and Frequency? Nappi185_imp 29 1,795 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 993 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 375 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,156 05-01-2015, 09:03 PM
