Electronic speed limiter worldwide applied? European CB1100EX owner here
EDIT: hmmmm, most important, I did forget to mention that I did ride with a huge topcase, 55 litre Givi E55 Maxia 3 Blush
[Image: 8d5b0ab32f0c92838edb3d8ccad7819d.jpg]
I assume this could cause the front to wobble at high speed?
Yea that could be critical information.
Remove it and go for a ride.
I can tell you that when I worked in the industry 30 years ago, there were some complaints about wobble on Gold Wings here in the USA. Honda attributed it to luggage racks and top cases and their fix was to affix this huge weight to the front of the steering head (maybe a loaded topcase unweights the front end?). I also know that Honda does not offer ST top cases in the US... but many members buy them from overseas. Maybe on some bikes the balance point is finely figured and changes to one end affects the other end?
With the front faring your down pressure on the front causes the rear to get light @ speed, the top case would increase wobble. Take it off and make sure that your screen is the same angle ( very important) as your front forks. The larger screens will cause side wind pressure, be careful with larger screens over 100MPH
I've had my CB up to 140+ with a cut down shield with no wobble or head shake. The screen helped stability.
I'm willing to bet it's the huge top case. Empty or loaded, it will have an adverse affect on high speed stability. Extra weight on the back will lighten up the front end. Also, the air currents coming around the front of the bike and your torso will catch that top case and create either wind buffeting or could but pushing down on the top case somewhat like a spoiler on a car. I also don't think you can rule out the fairing creating lift on the front end. The reason sport bikes have such a pointed nose is to help create down force up front. Same goes for the ugly beaks on adventure bikes. The Road Comet is somewhat blunt in profile, so it might be lifting the front of the bike.
(02-07-2016, 12:42 AM)The ferret_imp Wrote: Yea that could be critical information.
Interesting!
ST, meaning the Pan Am I assume?
(02-07-2016, 01:35 AM)CIP57_imp Wrote: With the front faring your down pressure on the front causes the rear to get light @ speed, the top case would increase wobble. Take it off and make sure that your screen is the same angle ( very important) as your front forks. The larger screens will cause side wind pressure, be careful with larger screens over 100MPH
aha! Smile
1 problem, I have the Road Comet I faring with the larger than stock touring screen, called Aero screen.
I cannot change anything on the fairing or on the screen. Undecided
But, I do plan to get the stock size screen wich should improve the wind noise....(and perhaps the wobbling at those speeds, not that I would ride so hard all the time, wrong bike and I dont really care, it was just to test Sleepy)
(02-07-2016, 03:14 AM)the_undecider_imp Wrote: I'm willing to bet it's the huge top case. Empty or loaded, it will have an adverse affect on high speed stability. Extra weight on the back will lighten up the front end. Also, the air currents coming around the front of the bike and your torso will catch that top case and create either wind buffeting or could but pushing down on the top case somewhat like a spoiler on a car. I also don't think you can rule out the fairing creating lift on the front end. The reason sport bikes have such a pointed nose is to help create down force up front. Same goes for the ugly beaks on adventure bikes. The Road Comet is somewhat blunt in profile, so it might be lifting the front of the bike.
actually, I did not felt a big difference in buffeting with that top case on, in the contrary I had the impression there was a bit less buffeting, especially from my back.
Does that sound valid? Huh
I also wonder how come on my Burgman 650 with topcase, I never experienced wobbling and it was really riding on rails at its topspeed of 107 mph...something to do with the layout?
The topcase on a burgman sits much higher than on a CB and it has sa HUGE windscreen.
They both weigh more or less the same too...260kg wet for the CB and 279 for the scooter Smile
ST is the ST1300 or the Pan European
I also owned a Burg 650 w/ an E55 Givi. Can honestly say that the Burg 650 is in a class all by itself. Aerodynamics (as well as that amazing e-cvt) is class leading, w/ or w/o top case. It's got all that tupperware on it, which cuts through the air w/ hardly any turbulence.
Do you have spoke wheels? If so, you may want to just double check that the rim is concentric, even though yours' still brand new. The spokes can/do stretch after break in, so they need to be tweaked every now and then to keep them true, even if you never hit a pothole.
Easy to do: Raise wheel off ground, use dial micrometer, contact pointer against inside surface of rim, rotate, and see how much the dial moves.
Dial indicator, dial micrometer...
Interesting!
aha! Smile
(02-07-2016, 05:05 AM)Lord Popgun_imp Wrote: ST is the ST1300 or the Pan European
lol and i said Pan Am Dodgy of course I meant Pan European.
[Image: 28a84445e133cfb70e75f033329290d9.jpg]
(02-07-2016, 05:15 AM)jedd_imp Wrote: I also owned a Burg 650 w/ an E55 Givi. Can honestly say that the Burg 650 is in a class all by itself. Aerodynamics (as well as that amazing e-cvt) is class leading, w/ or w/o top case. It's got all that tupperware on it, which cuts through the air w/ hardly any turbulence.
indeed, if i had place and cash immediately available I would still keep that scooter Smile
Do I have spokes??
Do members even watch the signatures of other members??????Big Grin
The link doesnt work btw.
lol, it seems members also dont read the whole thread huh Smile
(02-06-2016, 10:59 PM)Riko_imp Wrote: I had the fork boots intalled, and I stood by the mechanic and he had an expensive torque wrench and all is in spec Smile
So there is nothing wrong with torque settings in the forks or tripple tree.
Twisted chassis, hmm I doubt the issue is that extreme Pterodactyl.
I should actually let somebody ride my CB that has also a CB and tell me that its normal what I perceive as a wobbling handle bar. Smile
I'll ask asap 2 fellow countrymen what their experience is with high speed riding.
Head bearing torque I have not checked yet...I dont even know the torque setting, so if somebody could tell me that I can check that out, meanwhile I can do a search on the board.
I suspect the crosswinds, or me being extremely nitpicking.
But if you all say no wobble at all, thats clear and leaves no room for interpretation....
Than again, have those who say that ever ridden at those speeds with a lot of crosswinds??
But lol trading in, you guys really go for a worst case scenario huh Smile
(02-06-2016, 10:57 PM)redbirds_imp Wrote: Running at an indicated 90 mph on the super slab a while back, I experienced some front end wobble when approaching semi's. This wobble would stop when I cleared the turbulent air behind the trucks. This was with my Puig screen installed. Had not felt this wobble when in similar situations sans screen.
hm hm, that shines another perspective with more details concernikng my small issue.
With or without screen, does make a difference and you talk about turbulence as well, similar to my windy conditions.
(02-06-2016, 10:49 PM)soulmachine_imp Wrote: How's that grip on the bars at higher speed?
Keep that grip loose and I'll guarantee those wobbles go away...
lol, what do you mean exactly with "keep that grip loose" ?
at high speed?
shouldnt you be holding your grips firmer than ever as you increase speed Dodgy
aha, I don't seem to be the only one here Smile
http://www.cb1100forum.com/forum/showthr...p?tid=3034
I realize now that there are 2 kinda big weights sitting on the front around each spoke, maybe its an issue of tire balance as well.
Are spoked wheels more sensitive to changes in balance, (since they need adjustment from time to time)?
Meaning I asked that question too Wink
My mechanic will know what to do when I come in Smile
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,264 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 846 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  2017 Honda CB1100EX modifications kennyw 28 2,083 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,127 06-24-2023, 08:27 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 550 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,149 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,375 06-03-2022, 01:16 PM
  2017 CB1100EX Brake Bleeding M1tch_imp 1 296 03-05-2022, 04:29 PM
  Speed bleeders Raceman_imp 21 1,486 12-14-2021, 04:30 AM
