Checking the oil level
Yes technically 4.1 qts which I guess technically would be 4 qts 3.2 ounces with a filter. That's why I throw in 4 qts and don't worry about it lol.
Then again, 1 US gallon = 0.833 Imperial gallon so mind your unitz, boyz.
I used 1 us gallon and when checked, on level ground the view port was completely filled in. I guess I should not have bothered! Just, when over filled you can not tell by how much. Last time the engine was cold so probably had quite a bit of residual left. Thanks! Next time I'll drain warm, put in the gallon and be good!
Full synthetic Honda 10w30 + filter today 4qts
[url=http://s1030.photobucket.com/user/736ccdetail3/media/IMG_9739_zpsscrsivpx.jpg.html][Image: 03e2702a49b800da8fa336e681b0ad2d.jpg]h
With regard to oil level checks, i just found out that there is a check that works for me when the engine is running on flat ground on the centre stand.
the oil is at the low level mark if it is running and rises slowly to the top mark when stopped, this could be a double check
when over filled and above the window, but by how much?
If you run the engine and the level becomes visible you should be ok.
Maybe i'm to fussy but here goes; link to youtube; https://youtu.be/mEgQmyknW_4
All the best; Max
Thanks Max, informative video.
As my riding season is only 6 months long (May through October) and I ride once a week, I only average of 11,000 kilometers - 6835 miles each year. So my oil and filter change is done in early November when I put the bike to bed for the winter.
Which reminds me, I have to see if the Nelson-Rigg dust cover I used for my CB500XA will fit the CB1100 EX. I will remove the mirrors, as I did for the CB500, so it should be OK. Our 15 year old male cat loves to hide under the cover when the boss comes looking for him.
(05-05-2017, 12:20 PM)LongRanger_imp Wrote: I keep my CB on a battery tender, check the tires before each ride, clean and lube the chain after every few tanks, but I couldn't be bothered to check the oil level between changes. Ignoring it may be false economy, but the engine doesn't smoke or drip oil, the oil pressure light never illuminates while riding, the clutch and gearbox work perfectly, and I change it every 4000 miles anyway. Besides, I hate getting down on my knees. Anyone else as negligent as I am?
I check mine every weekend. I check all fluids in both bikes and my truck every weekend. Old habits just don't die.
  fuel level sensor MBZM Rai_imp 11 1,001 04-11-2023, 11:38 PM
  Checking valve clearances Maturecheese_imp 74 6,899 12-11-2022, 12:56 PM
  Oil Level Enzofour_imp 15 1,271 05-10-2021, 09:48 PM
  Low oil level mrded_imp 33 2,401 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,231 03-22-2021, 10:37 PM
  Oil level difference between check zirconxi_imp 29 2,021 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  Checking Drive Chain Slack Townie_imp 26 1,988 01-15-2020, 11:14 PM
Last Post: cocojamboo_imp
  Oil level question 562loosenoodle_imp 13 931 03-28-2019, 09:41 PM
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,306 02-11-2019, 01:55 PM
  Checking fuel gauge mattmcuomo@yahoo.com 2 323 06-01-2018, 02:52 AM
