Oil Level
Doubts about the oil level. with filter change and L. 3,750 of oil, the level is slightly above the upper mark.
The workshop manual says L. 3,900!?Dodgy.
How do you behave?
Personally, I dump a 1 gallon jug in and don't worry about it for 4000 miles.
Yeah, I didn't measure either. Dump, run, stop, look at level, top up if necessary, done.
This would last until the next oil change in 12 months.
I'm a little more "particular" than that - anal Big Grin Big Grin Big Grin
I like my oil level to be just a bit below the upper line.
Same experience. Did my first oil change today and ended up filling 3,7 litres. Level fairly much right between the lines.
I’ll admit that I’m in the “4 quarts and worry in 4K miles” camp.
I think I’ve looked at it a few times as long as I’m down there to lube the chain, and there’s oil visible in the window, so I don’t worry too much.
(05-10-2021, 02:24 AM)Olof_imp Wrote: Same experience. Did my first oil change today and ended up filling 3,7 litres. Level fairly much right between the lines.
Did you also change the oil filter?
(05-10-2021, 12:21 AM)Rocky_imp Wrote: I'm a little more "particular" than that - anal Big Grin Big Grin Big Grin
And what quantity do you put including the filter change?
Yes, Honda original
Yes, Honda original
Yes, Honda original
ok, you only base yourself on the level marks and not what the manual says.
Ciao Enzo,
appena fatto tagliando annuale per la garanzia, moto del 2019 con 3850km.. messi 3.8 litri d'olio, a freddo sul cavalletto centrale, la finestrella è completamente piena oltre al livello "normale", mah.. mi lascia onestamente perplesso.
Così come mi lascia perplesso il costo, per un semplice cambio olio e filtro olio: 201 euro !!!
inoltre hanno usato olio 10w-30, a te quale?
eng:
just done my annual service in order to keep the warranty ok; 2019 EX with 3850 km.. they put 3.8 liters of oil (1,004 gallons), and with the cold engine and standing on the center stand, the oil level window is completely full, way over the normale level.. I'm honestly puzzled if they put too much oil.
as I'm puzzled about the cost, for a simple oil and oil filter change: 201 euro (244,37 USD) !!
also, they used 10W-30 oil, which one do you guys use?
  fuel level sensor MBZM Rai_imp 11 904 04-11-2023, 11:38 PM
  Low oil level mrded_imp 33 2,215 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,116 03-22-2021, 10:37 PM
  Oil level difference between check zirconxi_imp 29 1,797 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  Oil level question 562loosenoodle_imp 13 800 03-28-2019, 09:41 PM
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,136 02-11-2019, 01:55 PM
  Checking the oil level LongRanger_imp 27 1,518 10-18-2017, 04:13 PM
Last Post: Jeffhorn_imp
  Oil Level Sight Glass Question olekzap_imp 9 720 07-01-2016, 06:59 AM
Last Post: Ulvetanna_imp
  Oil level went to lower level? mattmcuomo@yahoo.com 6 421 01-23-2016, 03:32 AM
  Question about oil level??? Johnboy_imp 24 1,458 11-06-2015, 01:13 PM
Last Post: kmoney_imp
