Oil level question
I got home from work and put the bike on the center stand. Figured I could wait five minutes and check the oil level. Well after thirty minutes the oil level showed a reading that was below the bottom line. Was the bike too hot to check? Or, am I low on oil. My next oil change is this Saturday. I guess my bike burns oil?
What do you think is going on?
Low on oil.
Not enough info to know if it is burning oil, but most likely not. check around the filter and drain plug for leaks. It may not have been filled properly last oil change.
Definitely low oil if after a few minutes of engine off time. The hot oil flows well in the direction of gravity.
Popgun's suggestions are a great first step.
If you don’t already try to check oil in the same level spot every time. Also, I find I have to top off oil somewhere around halfway between changes. I ride mine a lot at high and low speeds, high and low rpm so I’m sure some oil gets vaporized and burned. Just my 2 cents.
(03-28-2019, 01:30 AM)MMC_imp Wrote: If you don’t already try to check oil in the same level spot every time. Also, I find I have to top off oil somewhere around halfway between changes. I ride mine a lot at high and low speeds, high and low rpm so I’m sure some oil gets vaporized and burned. Just my 2 cents.
Good point MMC. I agree. If you gobble up RPM, then then some oil will blow by and burn.
I agree, after 30 minutes hot oil would have settled long ago.
Just needs to be topped up I would say.
Good advice from popgun Thumbs Up
Yeah, my oil change is this weekend. It just needed a little. I ride everyday about 70 miles.
My bike gives erratic and inconsistent oil level readings also. I brought this up in a thread a while back. I checked my oil level at home one time and was shocked to see it was low - I knew it shouldn't be low because I had recently checked it. I rode to the shop to buy a quart of oil and when I arrived there the oil level had returned to normal - it had changed from the lower line in the sight glass to the upper line. Bike was on center stand and on level ground both times, and was checked approximately 5 minutes after turning the motor off.
If there is no leak, bike is not burning oil, has no piston blow-by, is always on center stand and you have different oil level readings = you check your oil level at different conditions, i. e : too soon after shut off, not running bike for a while after oil/filter replacement or checking oil level when bike ran cold and too short.
The best and 100 y. o. perfect method is: center stand and next day= cannot go wrong.
* Assume: air cool engine, no fuel interference and I do not believe in engine oil vaporization during normal usage.
Before I start my bike, I have a quick look on the floor if any leak. I check engine oil level between intervals only if I go on very long/multi day trips. Done.
Ride it, do not babysit
(03-28-2019, 09:52 AM)Dave_imp Wrote: What do you think is going on?
I’ve had the same happen to me. Now I only check it in my garage in the same place every time. Make sure it’s hot and sits for awhile before you check too.
  fuel level sensor MBZM Rai_imp 11 930 04-11-2023, 11:38 PM
  Oil Level Enzofour_imp 15 1,222 05-10-2021, 09:48 PM
  Low oil level mrded_imp 33 2,284 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,161 03-22-2021, 10:37 PM
  Oil level difference between check zirconxi_imp 29 1,871 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,199 02-11-2019, 01:55 PM
  Checking the oil level LongRanger_imp 27 1,599 10-18-2017, 04:13 PM
Last Post: Jeffhorn_imp
  Oil Level Sight Glass Question olekzap_imp 9 756 07-01-2016, 06:59 AM
Last Post: Ulvetanna_imp
  Oil level went to lower level? mattmcuomo@yahoo.com 6 447 01-23-2016, 03:32 AM
  Question about oil level??? Johnboy_imp 24 1,521 11-06-2015, 01:13 PM
Last Post: kmoney_imp
