High oil level
Hi folks, Just asking if with fuel injection is it possible that petrol could be entering the sump because my oil level has risen and is now above the sight glass. It was near the bottom line before and nothing as been added.
I have not started any investigations as yet as only noticed it last time I put the bike away(cold) Its on my to do list over next few days starting with taking some oil out and of course smelling for petrol.
I had this problem with a XJR1300 carb model and found the petcock wasn't closing enough and a carb float valve wasn't seating right so the sump filled with petrol when the bike was parked.
I didn't think this could happen with fuel injection ???
Mixagon
My first thought is to put the bike on the center stand and check the oil (after you do the smell test). Then fire it up and let it warm up for 3-5 minutes. Then let it sit for 2-3 minutes and check the oil. This from the service manual. If low add more.
But it takes a while for ALL the oil to drain down and it doesn't take much to fill past the line. You think all is good and later you go back and look and its' too full. Both the CB and my ST1300 are aggravating in this way.
Others may have more info.
If gas got into the oil you should be able to have a faint smell of gas in the oil.
Do you always check oil level with the bike on its centerstand in the EXACT same spot? It takes very little difference in side-to-side floor level to change the apparent oil level in the sight glass. I've seen that happen for years on my old BMW K-bikes and it's true for my CB as well.
It's extremely unlikely that the FI on the CB is dumping gas into your oil, unless there is something terribly wrong. I think you'd be aware of running problems if that were occurring.
and again this is why I put the right amount of oil according to spec in when I change it (so I KNOW how much oil is in there) and don't worry about it again until the next oil change 4,000 miles later unless I see oil spots on the garage floor or smoke pouring out the tail pipe. If it ain't leaking or burning, the right amount of oil is in there, no matter what you see in the sight glass.
How many of these "the oil level in my site glass window is over full or under filled" (there's one of each on the front page right now) threads have we had in the last 8 years? Yet not a single thread about a Honda CB 1100 engine blowing up due to an oil issue ..... or any other issue for that matter.
As long as we need oil in our vehicles, it seems the legacy of oil myths will never cease. Undecided
The next generation of offspring are compelled to reinvent the concern.
I do it the same way as Ferrett , use 4 quarts , take 4 ounces out of the last quart and put it in the bike and do NOT worry !
(03-20-2021, 11:48 PM)The ferret_imp Wrote: and again this is why I put the right amount of oil according to spec in when I change it (so I KNOW how much oil is in there) and don't worry about it again until the next oil change 4,000 miles later unless I see oil spots on the garage floor or smoke pouring out the tail pipe. If it ain't leaking or burning, the right amount of oil is in there, no matter what you see in the sight glass.
Yes and so you should put the right amount of oil in but whoever changed my oil last (Honda Dealer) actually overfilled it so what would you do in this case.
Of course no one knows by how much its overfilled so you could have got your single case of engine damage if not checked. So I removed 500ml of overfill today and now the level is correct.
(03-20-2021, 08:38 PM)cookiemech_imp Wrote: Do you always check oil level with the bike on its centerstand in the EXACT same spot? It takes very little difference in side-to-side floor level to change the apparent oil level in the sight glass. I've seen that happen for years on my old BMW K-bikes and it's true for my CB as well.
Yep always in the same place for the last 20 years and checked regular with a spirit level.
I was just asking if FI could leak fuel into the sump when parked as per carb models can and do sometimes as I relayed about my XJR1300 but no one seems to know.
Ok checked today and no fuel in the sump it was just oil overfill by a Honda dealer they are far from perfect you know.
500ml taken out and now everything ok, I guess some will say it would have been ok to leave it in but until you start taking it out you don't know how much overfill there is so have to check, anyway all sorted now and next oil change will be done by me and be correct amount.
Mixagon
Mixagon, I’m pleased you sorted your problem. I can’t answer your question about whether it’s possible for fuel injected bikes to leak petrol into the sump, but I’m pretty sure no one on this forum has reported it happening on a 2010 and later CB1100. Oil leaking from a K&N filter is a different story.
Mixagon
Good find Mixagon. 500 mL sounds like a significant overfill.
  'Factory' high performance spark plugs PowerDubs_imp 17 1,492 10-23-2024, 02:50 PM
Last Post: rtmoto1
  High engine revs on start up CBX1000_imp 21 1,822 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,658 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,781 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  fuel level sensor MBZM Rai_imp 11 925 04-11-2023, 11:38 PM
  High mileage and oil consumption Jurlie_imp 24 2,131 04-07-2023, 06:05 AM
  High idle mattmcuomo@yahoo.com 7 690 10-29-2022, 11:09 AM
   Dutch's High idle thread DutchRutter 17 1,547 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 4,030 07-05-2022, 11:41 AM
  Really high idle Gordo_imp 124 10,137 11-16-2021, 02:37 PM
