Threads: 16
Just a quick question. I assume that checking the valve clearances involves removing the cam cover and using feeler gauges to check the clearances without removing anything like the camshafts as would be needed to replace them. I am asking as I want to know what is involved so that i can get some idea of what the cost is likely to be at my local dealer.
Likes Received: 610 in 274 posts
Likes Given: 786
That is correct..
inspection requires cover removal and measuring clearances
valve shim adjustment requires camshaft removal and new shims
Threads: 16
(11-28-2022, 01:55 AM)The ferret_imp Wrote: That is correct..
Thank you I thought that might be the case. In the spring I will be paying for a service so hopefully they can do this also.
Threads: 125
Just be aware- even 'just' removing the cam cover- and taking the time to *correctly* measure all 16 valves- then reassemble is still a few hours work.
And depending on how many miles on your bike- I'm not a fan of reusing old rubber gaskets exposed to heat / expansion / contraction cycles. I'd replace the gasket.
Threads: 63
Likes Given: 8
(11-28-2022, 12:32 PM)PowerDubs_imp Wrote: Just be aware- even 'just' removing the cam cover- and taking the time to *correctly* measure all 16 valves- then reassemble is still a few hours work.
I second these comments!
Threads: 4
I have an appointment to get mine inspected on 12/8. The local dealer only has one service tech qualified to do it, and the labor rate for that type of work is $130/hour. I'll post a breakdown of the parts & labor cost when i get the bike back.
Threads: 245
Likes Received: 1,194 in 513 posts
Likes Given: 966
I have an appointment to maybe think about checking mine at some undetermined point in the future.
(11-30-2022, 02:38 AM)Gone in 60_imp Wrote: I have an appointment to maybe think about checking mine at some undetermined point in the future.
Threads: 125
(11-30-2022, 02:10 AM)12milesout_imp Wrote: I have an appointment to get mine inspected on 12/8. The local dealer only has one service tech qualified to do it, and the labor rate for that type of work is $130/hour. I'll post a breakdown of the parts & labor cost when i get the bike back.
Sadly if it were my decision- if you couldn't do that job- you don't qualify as a service tech. <-- period.
Compared to things in the top / bottom end where clearances and attention to detail are critical... this is simplistic.
Threads: 1
Just a thought, you could take it in before spring. They are not very busy now and will be swamped in the spring. Everyone wants their bike ready at once the the weather breaks.
I used to do side work and everyone things they are your only customer. Part of the reason i stopped.
Otherwise your question has been answered above. It does take time to do even if no shimming is needed. TM
